Results 1 to 10 of 27
Thread: vec c egr(z22se)
    Regular Member denzilbud's Avatar
    cambridge
    Default vec c egr(z22se)
    hi all wondering if someone could offer some advice,ive read and followed the threads about removal and cleaning of said valve and have followed it best i could but none that i can find are specific to my engine and i cant work out what bits need to be cleaned and how,also could someone advise me on how much im looking at for a cam chain and fit but not vaux prices,cheers
    norn iron
    best advice i could give is z22se.com
    cambridge
    yeh asked on there as well mate
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    2 bolts and lift it out mate, just give it a general clean, fit a Vx blanking plate but keep the wiring attached and never worry about it again. The ECU still can see the EGR so all's well. Blanking plate costs about £5. Re the chain, PM Benny on SE, cant tell you how much he charges but it will be far cheaper than VX and possible most independents. He only used latest VX parts and is a VX mechanic to boot.
    cambridge
    nice one but if i use the blanking plate and theres a fault with the egr that will still throw up a fault
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by denzilbud View Post
    nice one but if i use the blanking plate and there's a fault with the egr that will still throw up a fault
    If the EGR just need a clean then you will be fine. If the EGR is faulty then buy the EGR Cheater from the Z22SE shop and totally get rid of the EGR.
    cambridge
    cheers mate so how do i clean it and what parts do i clean
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Just unbolt it, and get a tooth brush in there with some carb cleaner. Nothing to it really mate.
    cambridge
    cheers mate
    Regular Member old cruiser's Avatar
    slough
    As Rushy says mate , I've done it to mine, in fact taken off the egr altogether (cleaned up and sitting in the shed!!), blanked off and fitted the cheater, as you'll need this to stop any fault codes being thrown up, if you decided to blank off etc that is.
    Cheers Pete
  1. Problem with 2.2 sri (z22se)
    By mutley in forum Engine & Drivetrain
    Last Post: 7th May 2011, 16:00
  2. Z22se
    By Paddy in forum Engine & Drivetrain
    Last Post: 1st April 2011, 14:02
  3. z22se mpg
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 19:03
  4. z22se in a vec c
    By benny in forum Engine & Drivetrain
    Last Post: 30th August 2007, 00:05
egr disable tech 2 z22se
