Results 1 to 10 of 11
Thread: track rod ends
    Regular Member sristeven1's Avatar
    wirral
    Default track rod ends
    right bit of a odd one this i changed my trackrod ends yesterday and ever since then have had a break warning light come on on the dash any idear why this would happen has the breaks are sound got loads left on them
    Newcastle under Lyme
    probably either damaged the sensor cable or left disconnected
    wirral
    never had to touch any cables mate all i had to do was lossen 2 bolts off
    was any strain put on the cable?
    wirral
    not that i no of mate i took the wheel off again today to check and everythnig looks spot on very odd
    just thinking it may have broken a cable inside. Im sure someone else will be along soon with other ideas but thats the best Ive got hth
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    check the rears m8,
    Won't be the rears Glynn - they've never had a sensor wire.
    I'd say the same as JSYSH466Y - it may not be obvious but the sensor wire on the front nearside may have got damaged or slightly dislodged.
    wirral
    going to take the wheel off again in a min and check every thing let you no how i get on
    wirral
    well whell been off again nothing is broken or loose so got no idear checked all the break bads while i was there just incase and they fine got loads left on them will keep a eye on it not worryed at the min as i no every thing is fine with the car so will get it in to get looked as as soon as i can
  1. Replies: 5
    Last Post: 15th July 2010, 21:33
  2. track rod ends
    By monty2000 in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2010, 10:23
  3. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
  4. Track Rod Ends Help
    Last Post: 23rd April 2010, 14:13
  5. Track Rod Ends
    By parapaul in forum The 'Off Topic' room
    Last Post: 13th March 2008, 01:05
