Results 1 to 10 of 19
Thread: Do these swirl look broken
    Regular Member sirnapper's Avatar
    Ldon
    Default Do these swirl look broken
    Hello, I was just checking the swirl valves because I was getting low power at low revs. Do these broke first time ive seen a swirl valve soo I dont have a clue what they normally look like
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Not broken, but showing the signs of wear/age as it does with the older type manifold.
    Mine looked like that till i degreased and yet washed it, and promptly watched the rod fall off! Its not laying at the bottom and thats where its staying!! for now...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    It looks ok just now as that rail is usually completely off if it is broken, although I would say it is starting to break as you have alot of oil and soot caused by the up and down movement of the swirl flap bearings.
    Gazza4
    Blantyre
    Cant see for the dirt mate
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    what does the swirl do? (KEEP IT SIMPLE PLEASE)
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    alters the airflow to improve combustion depending on RPM
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    thanks... i understood that!
    Ldon
    Thank god for that, £500 is something i dont have right at the moment lol ive cleaned out the EGR valve and boost sensor soo hopefully this sorts out the power issues. Thanks for the replys guys, do u guys recommend degreasing the area around it carefully ?
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    not really no. Otherwise you'd possibly knock the rod off, its a PITA to get back on which is why i've left mine. also as i found out because of the up/down movement on it water can seep into the chamber too!! very bad....
    Ldon
    I love the car, hate the problems
  1. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  2. swirl or not to swirl
    By lesron in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 19:53
  3. Broken swirl valve??
    By signumkev in forum Engine & Drivetrain
    Last Post: 8th May 2011, 20:35
  4. Swirl bar broken, anyone in glasgow/hamilton area fancy a homer?
    By LEW1S2006 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 18:24
