Thread: 6 speed F40 are they all the same?
    Scottish Borders
    confused 6 speed F40 are they all the same?
    Hi all.
    I have a 04 Vectra energy CDTI 120 with a 6 speed F40 box.
    I will miss out the borring lead up to this event but while limping home 60 miles with no clutch I got some nasty noises from the box in the last mile and on draining it found some chunks of metal(do i hear shouts of "you twit")
    My local breaker has a F40 still in a SRI CDTI so I can't see the input shaft etc.
    Are the 8v and 16v boxes exactly the same? as the clutch kits and dual mass flywheel appear to be different.
    Any pointers?
    Chris
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    the ratios in the 8V are slightly closer than that of the 16.
    The F40 in the 3.0CDTI is slightly wider than the 1.9 16V.
    Generally the Diesels have wider ratios than the petrol F40's because of the torque they can deal with tougher gearing.
    Gazza4
    Scottish Borders
    Thumbs up
    Cheers Gazza4
    Any idea about the external differences of the box that might prevent it being a straight swap?
    Chris
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by firenza73 View Post
    Cheers Gazza4
    Chris
    I dont think do if you are swapping the F40 box for another there sould be an issue its just the ratios that differ.
    Gazza4
    Scottish Borders
    Thanks for the advice.
    Chris
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Chris
    Sorry m8 there shouldnt be an issue - sorry typo on my part
    Gazza4
    EVERYWHERE
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    I thought that only the 2 litre turbo had the 'close-ratio' box,and all the diesel CDTIs had the 'wide-ratio' box with the same diff ratio ?
    Any info ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by diesel dog View Post
    Any info ?
    Thats what I said all of the deisels have the wider ratios and all of the petrol albeit 1 have close.
    Same ratio from 1-6 only the final drive changes.
    Gazza4
    EVERYWHERE
    Gazza4
    The only final drive ratio ratio I have come across is 3.55 to 1 for all the F40 diesel variants.It would seem a bit odd that the 120 and the V6 should have the same ratios though?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cost effedct?? Easier to change one ration than change a few. There is 3.55:1 and 3.72:1 (Not 100%)
    Gazza4
  1. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  2. Speed limits & speed cameras.
    By kentish_bloke in forum General Chat
    Last Post: 15th February 2010, 21:22
  3. Z22YH 5 speed or 6 speed
    By caigey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 11:56
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
  5. Speed Camera's / Mobile speed traps M6>M61
    By suj786 in forum General Chat
    Last Post: 10th March 2006, 22:38
