Results 1 to 10 of 19
Thread: What tools?
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Default What tools?
    Can anyone tell me what tools are required to change the rear suspension (springs & shocks)?
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by Matt21385
    Does anyone know the size of the socket to remove the shocks & is it a bi-hexagon socket?
    cheers
    Set of spring compressors to be safe, and a torx socket IIRC.. The dampers are now independant of the springs, more like the old cavalier than the vectra B.. but i'm not sure if there is enough 'droop' in the linkage to allow the spring out without being compressed..Top shock mount is externally mounted behind the wheel but may be covered in mud so plenty of WD40..
    Dec 2005
    In the sponge-monkey tent
    Quote Originally Posted by Gsi3.2
    . but i'm not sure if there is enough 'droop' in the linkage to allow the spring out without being compressed...
    My fitter compressed the springs when changing mine, not sure whether he 'needed' to or just did it anyway to be safe.
    Prob to be safe.. I wouldn't want to catch a flying coil spring in me teeth
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Cheers for that guys
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Do you know what size the sockets are, to save me buying a full set that I will probably only use the 1 or 2 sockets out of?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    I would buy a full set for the sake of it.
    Looking at them looks around a 10 or 12. But for the sake of a £7 from Machine Mart, get them bought.
    Spring compressors I would always use just to be safe Rears arn't needed but fronts yes.
    I'll slip a socket on the bolts in the morning.. the neighbours will think i've cracked if they see me now..
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by CDTi
    Full set it is then. Already have the compressors. used them on my last car but didnt need torx sockets
  1. Tools what do you have?
    By Bigtee in forum General Motoring Chat
    Last Post: 31st January 2012, 13:58
  2. Tools
    By Graeme in forum General Chat
    Last Post: 31st December 2010, 23:25
  3. Most used tools
    By Tadpole in forum General Chat
    Last Post: 25th January 2009, 22:09
  4. tools
    By jack in forum General Chat
    Last Post: 27th December 2008, 15:08
  5. Tools
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2008, 23:45
