Thread: Debadging
    Regular Member saintdean's Avatar
    Jun 2009
    Northampton
    Default Debadging
    http://www.desolvit.co.uk/pages/desolvit_spray.htm
    just brought a bottle of this. You think its ok and not to strong to remove the paint.
    Regular Member Bigdavesafro's Avatar
    Halesowen
    I did my rear end Griffin and door mouldings on Saturday with a credit card and Turtle Wax Bug and Tar remover. The stuff polished up great. If this stuff is just a remover you'll need some polish as well!
    Regular Member davidlewis24's Avatar
    bridgend / wales
    hi mate i got my friend to do mine yesterday he used a heat gun to prise away the badge ( just dont go to close to the body work ) and then used a fudge ball that attached to a drill and went over the sticky stuff with this fudge ball and WOW took seconds no marks what so ever hope it helps
    Regular Member collow123's Avatar
    cumnock ayrshire
    I used a bit of fishing line and the good old turtle wax bug and tar ..... Left next to no sticky stuff on car so it was only a quick wipe with bug and tar remover and a final polish to protect the paint .... Job done
    Jun 2009
    Northampton
    The stuff removes tar, so i guess it should work no probs. this stuff is a spray and i spray a couple of time and wait then clean off.
    Regular Member robster23's Avatar
    Hastings
    I peeled gently and used Tcut for the last bit of stuborn stuff. Nothing specialised required!
    cumnock ayrshire
    Yep just spray on and leave .... The only problem is that the sticky stuff has foam between it and the badge so may need to try and soak the foam in the spray so it gets to the glue
    Jun 2009
    Northampton
    No problem, ill plan to do it this weekend. I want to remove the side badges too "Elegance" down the side.
  1. Debadging help please
    By eve01rton in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 21:21
  2. Debadging
    By affirmation in forum Styling
    Last Post: 30th October 2009, 19:35
  3. debadging
    By paul.sessions in forum Photoshop section
    Last Post: 3rd September 2009, 17:36
  4. Debadging my vec
    By veccyjim in forum Styling
    Last Post: 21st May 2009, 22:05
  5. Debadging
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2009, 20:16
