Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Help cleaning EGR valve
    Retford
    Question Help cleaning EGR valve
    Hi, i have a 06 Vectra SRI 150 (33k miles)
    My car seems to have intermittent problems with low down power, resposiveness etc. One day i pull out a junction it seems OK and another it seems sluggish.
    I live in Retford, Notts which is near Worksop - I was wondering if anyone local to me would want a weekend job taking EGR off and cleaning, and thus paying cash? Im convinced its sticking and/or not working correctly
    I prefer someone with experience of doing this before, im fed up taking to my local garage as they say nothings wrong and dont check or do what i ask . There is another place but they are expensive
    Chris
    Birmingham
    Chris, honestly bud, its a DIY job. I was reluctant to do my dad's one over the weekend, but in the end just got to it and was done well within an hour.
    Here's my thread of how it looked: http://www.vectra-c.com/forum/showthread.php?t=86097.
    Just make sure you get the gaskets before hand and off you go!
    Bye bye Vec B
    - Hello Siggy!
    Full Member spennny's Avatar
    Blantyre
    The fiat gasket is supposed to help reduce carbon build up , maybe one of those also for a few quid
    Birmingham
    Quote Originally Posted by spennny View Post
    Sorry to this Paul and Chris, but I read that too after I had fitted my replacement one. It has 2 small holes as opossed to the whopping great big one....I just wanted to know if this has any adverse effects?
    My thinking was that there is an obvious reason why Vx have the one with a big hole, so why should I use the small one and will it affect anything, e.g. performance, running, mpg??
    Bye bye Vec B
    - Hello Siggy!
    Winteringham
    Have you got the part number for that gasket?
    Retford
    Problem is my job is working in IT - i know as much about cars as the backside of the moon
    If it is that easy could someone please take a pic of the engine and where the part is - also do u have to unplug any electrics or anything before you start?
    I really would prefer to get someone else to do it - gimme a computer anyday
    Birmingham
    Try this thread Chris: http://www.vectra-c.com/forum/showth...t=cleaning+EGR, there are loads of good images here!
    The EGR valve is at the back of the engine on the right hand side! Its actually mounted flat on the back. Take the Ecotec cover off and its there!
    You will identify by seeing that it has a black device that is screwed into a aluminium type casting! The black part has one electric plug on it, but pull the yellow clip and it pops off! It also has bolted onto it, with 2 nuts, a clip that holds on of the rubber gromits for the engione cover!
    Aint got no piccies here otherwise would post one.
    The EGR valve comes away from the engine with 4 x 10mm bolts and away from the pipe below it with 2 x 13mm bolts!
    HTH a little!
    Bye bye Vec B
    - Hello Siggy!
    Retford
    Thanks for your help Vaux-Man-G !!
    So i dont have to worry about unplugging any other electrics - i just undo the yellow clip?
    Birmingham
    Quote Originally Posted by eraser2002 View Post
    On the plastic black side of the EGR valve (the solenoid side) there will be a black/grey plug plugged into the solenoid. On this plug will be a little yellow gromit which you will need to slide either back or forth (cant quite remember), this is bascially like a lock, once this has moce out of the way, you should be able to pull the plug off gently, I think you have to sqeeuze inwards where the yellow slider gromit thing was!
    Can you get an image of that area of your engine, can point you in the right direction then! Im at work ATM so cannot get an image!
    Bye bye Vec B
    - Hello Siggy!
    Retford
    Thanks matey ! - ill have a look tonight if i can and maybe take a pic or two to double check
  1. Cleaning EGR Valve?
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2014, 12:48
  2. Cleaning of EGR valve
    By inverkip1 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2009, 20:01
  3. Cleaning EGR valve ?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 8th January 2008, 09:33
