Thread: Water dripping from bulkhead after long drive with AirCon
    Regular Member muffking's Avatar
    Default Water dripping from bulkhead after long drive with AirCon
    Hi Guys.
    Just done a 90 mile drive on what was a hot day and noticed a puddle under the car when I parked up. It seems to be dripping down the lower part of the bulkhead in the engine bay. Looks like clean water and doesn't smell, so I checked the levels which are all ok and engine temp was normal at 90 degrees.
    This only happened with the AirCon ON so I wondered if this could have been condensation at the back of the engine and was normal as it stopped when I went for a drive with the AirCon OFF.
    Cambridgeshire
    All normal mate. That's what the Aircon does....I'm sure someone will explain why in a minute
    Plymouth
    Normal as anything... I had the same panic myself
    See HERE
    Its basically where air is condensing and turning into water.. It drips from a pipe just behind ur engine.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes all normal they all drip water from the AC unit thats how its works. By turning the hot air into cold air makes condensation just like a fridge does. Thats why they have a drip pipe at the back off the fridge, just that on cars they drip on to the floor.
    Phew, thanks guys, panic over.
    I've had the car for 3 or 4 years now and never noticed it before. You're all spot on about the pipe though as that's exactly where it was coming from, almost as if Vauxhall put it there to act as a route for the water to run from
    Regular Member marky2027's Avatar
    Northumberland
    Quote Originally Posted by muffking View Post
    Hi Guys.
    What did it taste like?? Mmmmm
  1. Water dripping under car?
    By JherekC in forum Engine & Drivetrain
    Last Post: 31st July 2012, 21:50
  2. what happend when you dont use aircon for a long period?
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2012, 19:13
  3. Water leak from bulkhead??
    By dap1977 in forum Engine & Drivetrain
    Last Post: 9th October 2011, 11:02
  4. Ebay bargain? = long long drive
    By Pecojess in forum The 'Off Topic' room
    Last Post: 1st April 2009, 23:41
  5. Water Dripping
    By bowler in forum Engine & Drivetrain
    Last Post: 8th June 2006, 22:40
vec c baulkhead
