Results 1 to 2 of 2
Thread: camshaft removal help?
    Ashford, Kent
    Default camshaft removal help?
    i know ive posted a few times over the passed few days regarding the silly mistake i made with the petrol into a diesel car.
    unfortunaly its done more damage then i had hoped for had the car running pretty well but after a short period had a knocking from the top of the endine, after takeing the rocker box off found that one of the valve rockers has snaped, does anyone have any advice on removeing the cam safely withought putting everything out of time, have an idea but dont want to make a silly mistake while getting the work done thanks
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Can you not lock everything with appropriate drill bits? Its usually the case as in 5mm drill bit through gear wheel into block. Set it all to TDC and i'm sure every hole lines up?
  1. camshaft pulley removal
    By Harlboy in forum Engine & Drivetrain
    Last Post: 26th December 2012, 18:17
  2. Is this a camshaft oil seal?
    By dae36 in forum Engine & Drivetrain
    Last Post: 18th January 2010, 16:10
  3. Camshaft Leak
    By Rebellion8878 in forum Engine & Drivetrain
    Last Post: 4th January 2010, 18:38
  4. Camshaft
    By Rebellion8878 in forum Petrol Engine related
    Last Post: 3rd January 2010, 15:51
  5. camshaft
    By darren klershaw in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 22:18
vauxhall signum 2.2 removing camshaft
