Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Help ! Help ! Help ! - MY PETROL CAR IS FULL OF DIESEL
    Regular Member suj786's Avatar
    glasgow
    Default Help ! Help ! Help ! - MY PETROL CAR IS FULL OF DIESEL
    MY PETROL CAR IS FULL OF DESIEL
    I took my sisters corsa to work yesterday as my dad needed my car for a run accross edinburgh. (he needed the sat nav) I came home from work yesterday to find my car's not on the driveway. Anyway 1am didnt want to wake him. But this morning he tells me he managed to fill it up with Diesel last night and its broken down.
    The car was running on reserve e.g no petrol. my dad filled the tank thinking he was doing me a favour. so nearly 50 litres of Diesel went in. AND he drove it for 300 yards before it start coughing spluttering and finally stalled. The cars been taken to my dads pals garage. so he will let us know today what's needing done.
    I've never met this guy before and dont know how good he is. But I'm going to see him in a couple of hours. What should I know about this. for example what will be damaged, what will need changed. I want to be confident he knows what he's doing before he starts pulling things apart.
    any advice would be greatly appreciated guys.
    Dec 2005
    In the sponge-monkey tent
    IIRC from a mishap my sister had with a cavalier, all that needed doing was flushing the tank and fuel system, the cost was about £120 roughly 3 years ago. No major damage was done and the car was fine after.
    Mileage : 000
    I will second that. it should not do any damage if it is flushed out, deisel is only an oil and any traces should burn off with the petrol....
    Regular Member Ian's Avatar
    York
    yep you should have no worries in just emptying the tank, and lush through the pipes. The other way round, petrol into a diesel is a complete no no.
    Here, there and every where!
    As long as it is flushed out thoroughly it should be ok. It might be a bit smokey for a few miles whilst the remaining diesel is burnt off.
    By the time your Dad has had it flushed out, filled you up, this time with petrol, it would have been cheaper for him to get himself a Tom Tom
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    Quote Originally Posted by Ian
    Confession time -
    I've done that - it drove for 10 miles but it wasnt too happy and koncked out as I pulled in to the dealer forecourt parking space. You are OK with a normal diesel engine I was advised (Phew!!) and all it took was a flush, new filter and refill.
    If it was a common rail then he told me it would have been rather more expensive.
    glasgow
    jus back from the garage. the mechanic insists it needs new fuel injectors, Fuel pump, throttle body. Vauxhall quoted £800. the mech has sourced a 6 month old veccy in a scrappy and can get everything for £550..
    I'm absolutely ferkin gutted. is this necesary. the mech said that the said parts have burned/corroded ???
    need to rush of to work. I'll be back on tonight
    Personally m8, i think he's having you over!
    Dec 2005
    Been looking around the net and the worst case scenario i've found on putting diesel in a petrol is a bit of smoking whilst the last of the diesel burns off and it's possible to kill the cat, but not seen any of these problems mentioned anywhere.
    The tech info from TIS is basically that these symptoms may occur....
    Following complaints could happen in one or several of them:
    • Piston top land broken (intake side)
    • Bad engine running especially after cold start and cold drive ability
    • Knocking noise (sometimes failure code P030X is set)
    • Molten catalytic converter as a consequential damage
    • Increased oil level (oil dilution)
    PDF here with some extra info.
    Certainly nothing about the other stuff your Dad's pal mentioned!
    HTH
  1. Petrol or Diesel
    By Madmarky01 in forum General Chat
    Last Post: 5th September 2012, 09:06
  2. Petrol or diesel
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 14:11
  3. 1.8 Petrol or 1.9 Diesel SRi
    By gavmckay in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 21:57
  4. Diesel Vs Petrol again..
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2008, 09:15
