Thread: sat nav
    Regular Member ADAM123's Avatar
    Jan 2008
    UK
    Default sat nav
    hello, i own a 2003 vectra c sxi. i think its half cambus (3 round button steering wheel) is it possible for me to retro fit vx satnav to it? ie cd70 or a half cambus sat nav?..
    thanks
    Surrey
    CD70 is full can bus.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Must exchange the CIM module and then you can fit the CD70 NAvi and wheel remote controls, also CID display.
    CristianTM.
    Surrey
    What about the ISO to quadlock wiring?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by CristianTM View Post
    CristianTM.
    You maybe right but not sure why you would need to change CIM module ?
    As above you would need to change from iso ---- quadlock then add wires to CD70 & CID & DIAG plug,then change steering wheel to full canbus one with airbag.
    You would be better off fitting a NCDC2013/15 this is a sat nav system for a half canbus car all though you would still need to alter loom to make it fit like i have
    Vectra 2003 have CIM version 1 and after 2005 appear CIM version 2 which recognize remote button controls and scroll remote controls, also "knows" the commands to CD70 NAvi. The CIM version 1 not knows to communicate with the CD70 NAvi.
    CristianTM.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Well i never knew that thanks Christian sort of confirms what i thought,what an expense it would be to add a CD70 just for nav
    YES ! A little expensive !
    For the exchange on a Vecky '02-'03 the combination CID + CD70 NAvi or DVD90 NAvi instead CD30 or CDR2005 or another audio must prepare:
    1. Insert the CID display (mount 32 pin connector if not have it)
    2. Exchange the Front Air Vents
    3. Insert CD 70 Navi or DVD90 Navi. Mount FAKRA connector if don't have it.
    4. Put RGB cable betwen navi and display
    5. Mount an GPS antenna
    6. Program all with Tech 2 if the CID and Navi are un-married.
    7. Put the all cable and wiring / connectors (if not fit it).
    8. Exchange the CIM module if you want the remote controls
    CristianTM.
