Thanks Thanks:  1
Likes Likes:  3
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 78
Thread: CD70 into non-canbus car
  1. #21
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    backlighting is normally marked up a 'led dimming control' from the BCM, so wonder if thats the same for illumination on the radio?
  2. #22
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    The CD70 requires inputs from the BCM for lighting control and also either the BCM or CIM for the temperature sensing.
    I can only assume now that these inputs are in the form of a digital signal (binary code), rather than the old style voltage across the relevant can-but paired wires...green for mid-speed can High and white for mid-speed can Low (I assume green is for signal and white is for ground).
    There is also a low speed can pairing as well but the inputs for this baffles me further.
    I don't want to apply a voltage across the green / white pairing just in-case I blow the pants off the head unit...It would be easier for me to install some small LED's myself via a flying leads that are linked to my existing car's ignition live and switched lighting circuits.
    There is bags of space within the chassis of the head-unit to pass these flying leads through.
  3. #23
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    I'll stick my meter on the LED dimming control voltage and see what it reads and see if i can replicate its function out of the car.
  4. #24
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    These are the pin outs for the GID or CID as I have it connected...as said above mine is a GID (late 2004 spec).
    GID SCREEN – Full CAN for 2004 onward screens.
    Pin No Colour Function Goes to:-
    1 Brown Ground Ground / Chassis / Earth
    2 Brown Ground Linked to pin 1
    3 Red +12 Volt Linked to pin 5
    4 --------- Not Used
    5 Red + 12 Volt To supply fuse FI17 (At side of Dash)
    6 --------- Not Used
    7 --------- Not Used
    8 Blue Data Line to radio pin 39
    9 Yellow Data Line to radio pin 33
    10 upto 16 - Not Used
    17 Green Mid Speed CAN Hi BCM Climate Control / DAB
    18 White Mid Speed CAN Lo BCM Climate Control / DAB
    19 White Mid Speed CAN Lo to radio pin 10
    20 Green Mid Speed CAN Hi to radio pin 9
    21 --------- Not Used
    22 Green Mid Speed CAN Hi to diagnostic link (BCM)
    23 White Mid Speed CAN Lo to diagnostic link (BCM)
    24 not coloured Data Line Ground to radio pin 12
    25 Green Lo-Speed CAN Hi ????
    26 & 27 ------ Not Used
    28 Green Lo Speed CAN Hi
    29 onward…not used
    For my Non CAN vehicle fitting GID pin 22 was linked to radio pin 9 and
    GID pin 23 was linked to radio pin 10…
    I haven’t found connections for my GID pins 19 & 20.
    I only used the connections that are |Not shown in Black writing.
    If you have a CID screen, you will need a VGA link cable…the wires for this are
    VGA plug pin no. Colour Goes to Radio VGA plug pin no.
    1 Grey 5
    2 Brown 1
    7 Blue 3
    8 Brown 4
    10 Sheath 10
    11 Sheath 9
    15 Red 8
    16 Green 7
    It is easier to get a link cable from a donor / scrap vehicle.
    Pin-outs for the radio to follow.
    Last edited by Robsey; 8th July 2009 at 22:03. Reason: apologies for format lost by posting
  5. #25
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    RADIO CONNECTIOS ARE AS FOLLOWS: -
    Radio Connections for 2004 Onward…CD30, CDC40, CD70
    Radio Pin No Colour Function Goes to: -
    1 white speaker wire speaker loom
    2 yellow speaker wire speaker loom
    3 blue speaker wire speaker loom
    4 green speaker wire speaker loom
    5 brown/white speaker wire speaker loom
    6 brown/yellow speaker wire speaker loom
    7 brown/blue speaker wire speaker loom
    8 brown/green speaker wire speaker loom
    9 GREEN HI SP’D CAN GID pin 22 (should be 20)
    10 WHITE HI SP’D CAN GID pin 23 (should be 19)
    11 Black Telephone
    12 Brown ground Chassis ground and GID pin 24
    13 red/white data link twin audio / travel assistant
    14 white speaker wire speaker loom
    15 RED +12V Instrument Fuse (FI1)
    16 yellow speaker wire speaker loom
    17 blue/red data link Twin Audio/ Travel Assistant
    19 sheath data link Twin Audio / Travel Assistant
    20 Grey data link Twin Audio / Travel Assistant
    23 green/white data link Twin Audio / Travel Assistant
    29 sheath Telephone Microphone
    30 orange/grey Data link Air Bag and Telephone
    31 green/brown data link DAB unit
    32 Blue/red data link DAB unit
    33 YELLOW GID LINK GID pin 9
    34 Blue Telephone
    35 Blue/red Telephone Microphone
    37 BLUE/RED Speed sensor ABS pick-up
    38 Sheath Data link DAB unit
    39 BLUE GID LINK GID pin 8
    40 Brown Telephone
    For the VGA wire colours please see post referring to GID pin-outs above.
    Hope this is of use...
    Last edited by Robsey; 8th July 2009 at 22:41. Reason: Apologies...seam to lose spaces and tabs when posting
  6. #26
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    This is my proposed before and after
    My Cav as it is now
    followed by my Cav with CD70
    I suppose to keep with Vectra C thing, I should say this is my Vectra A...
  7. #27
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    sugention why not remove the center vents and put the screen there?
  8. #28
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    I don't want to use my centre vents for 2 reasons..
    1) I use them a lot to keep cool...
    2) The screen is much bigger than the vent aperture...
    A second thought I had was to put the screen in the cubby-hole above my glove box as I don't have a passenger air-bag.
    I use my near-side mirror quite a lot, so it's not as if I don't look that way anyway....
    Plasma, did you get anywhere with the led dimming control?
    my only concern was that a lot of Vx electronic devices don't like digital test meters...I believe some damage can be caused in some cases...er on the side of caution...I'd rather you didn't check it, rather than you wrecked your own...this is only a pet project of mine and is not urgent enough to risk your own kit.
  9. #29
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Well it's been a while now and here is the progress so far.
    I got the following parts: -
    1) SOT122 lead, which I slightly modified to allow me to wire up the display, the head unit and an auxilliary input or blue toot if I wish.
    2) An old tom tom go (4 yr old model) aerial and fitted a fakra plug to it.
    3) An ISO to fakra aerial conversion lead
    4) Got a donor Cav heater control panel and cut and shut the GID screen surround into the Black heater Board Computer plastic panel.
    I have got the electrics all working (except for the BC functions, head unit lighting and ambient temperature reading as expected).
    Here is the display fitted into the heater panel.
    As stated above, I will be fitting different bowden cables and mounting the heater panel where the fag lighter currently sits.
    The big job is yet to come...making a whole new radio panel surround that doesn't look like a dogs dinner!!!
    It will be a very slow "work in progress" type thing as I am having to do a few bits here and a few bits there.
    Although I've now got the bug to get it done!!!
    Here is the screen mounted into the "Ex" heater panel and it's position in relation to the head unit. sorry about the picture...taken with my phone camera
  10. #30
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Thumbs up
    Continueing on, I have done a trial fit in my car today...
    Not for the faint hearted, had to hack a few sections out of my dash to allow the rather tall screen trim to fit under the centre air vents, and also remove the centre cross spar that holds the plastic shell that locates the radio cage.
    As a temporary thing, I tucked my blower cables out the way and set the blower to speed two, before tucking the switch away also...This will all be relocated where the ashtray sits in due course.
    Gave it a test on the way home and all the following functions worked perfectly..
    Sat Nav...took about twenty minutes to lock onto the car, but this only applies on first power up after installation.
    Radio...works brilliantly even with the aerial down (there are two tuners in the nav unit...the second is for TMC)
    CD and MP3 with ID3 tagging...if you can read my display in the picture, you will see I'm an 80's music fan.
    So here it is installed!!!
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  3. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
  4. CD70 screen in a 04reg preface half canbus
    By andyman201 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 14:43
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
https:www.vectra-c.comforumshowthread.php86197-CD70-into-non-canbus-carpage8
vectra c cim pinout
cd70 no canbus
pinout bcm vectra c
opel cd70 pinout
vectra c cd70 pin out
cd 70 can bus
cd70 pinout
pinout fakra cd70
vectra 2004 cim pinout
