Results 1 to 3 of 3
Thread: Misfire on cylinder 4
    atherstone
    Default Misfire on cylinder 4
    had loads of work including coil pack, plugs compression test, etc but cant get this ****** thing solved, ive mentioned to mechanics about it maybe injectors ecu etc but they have said they can try it but they would expect those faults to register on the diagnostis computer. is this true, or if you have any other ideas of what this problem could be please let me know!
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    first and cheapest thing, swap the plugs to eliminate them.could be the coil pack, starts getting expensive then. I would have thought a reader would come up with a code? point you in the right direction, what are the symptoms?
    atherstone
    go to pull off and constantly splutters and makes pulling off like im kangarooing the car, can also happen if im driving on motorway all of a sudden it might kick in and loss of power although not enough to actually make me stop and if on a flat road i can still accelerate. the engine management light is permanently on. hope this is of help as its the ebst way i can describe it. i have swapped the plugs around to see if the fault moves but no good. like i say i have changed the coil pack but no good.
  1. Vectra C 2.2 Misfire on Cylinder 3 + 4
    By m2yuout in forum Engine & Drivetrain
    Last Post: 12th February 2013, 13:14
  2. 0302 - cylinder 2 misfire detected
    By kristian in forum Engine & Drivetrain
    Last Post: 26th September 2011, 19:28
  3. misfire on cylinder no 3
    By WRed in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2011, 00:50
  4. Misfire on Cylinder No 3
    By WRed in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 13:58
  5. Misfire on Cylinder 4 - signum 2.2
    By H3MSY in forum Engine & Drivetrain
    Last Post: 18th January 2010, 13:53
