Thread: vacuum solanoid
    wirral,merseyside
    Default vacuum solanoid
    already purchased+replaced one of them witch was the 1 by the front grille but im trying to find out the part no for the other solanoid that is inbetween the battery+engine block(if you no wher i mean)as is it diferent to the one i have already replaced
    any help appreciated
    wirral,merseyside
    any 1 got any info on this 1 ive spotted photos of it before on this forum circled saying change it if your car always goes in to limpb mode.
    any idea
    wirral,merseyside
    here are the fault codes im throwing up+as said in top post ive already changed one of the exhaust gas resirc valves but ther is another 1 ther.its got a bosch part no on it
    p0400-5a exhaust gas recircultion flow insufficient detected
    p0105-03 Boost pressure sensor circuit low imput
    p0400-f8 Exhaust gas recirculation valvue feedback signal malfunaction
    p0110-07 intake air temperature sensor circuit high input
    p0234-5a boost pressure control circuit negative deviation
    Regular Member Jezzy's Avatar
    S.E
    For the 2.2DTR engine (is that the one you have?) there's a part number 93169058, described as "valve, assembly, exhaust gas recirculation, exchange".
    wirral,merseyside
    yes mate 2.2 dti would of been a good idea to include what engine wouldnt it
    could be what im looking for mate cheers will try dig up that part number sumwer
  1. oil vacuum
    By Al 22 dti in forum The 'Off Topic' room
    Last Post: 16th February 2012, 12:12
  2. AFR & vacuum gauge 3.2
    By TimTay in forum Styling
    Last Post: 14th November 2011, 01:40
  3. vacuum
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 17:59
  4. Z19DT vacuum.what is this?
    By tox in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 15:50
  5. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
