Thread: How easy is it to change the fuel filter?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default How easy is it to change the fuel filter?
    I dont have a tidy jack or axle stands ( usually drive up on bricks to change the oil lol). Does the filter come with new clips? ( its a 06 1.8 lifer )
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by PeterVV View Post
    Its relativley mate easy , there are 2 clips, one each end, if you have long nose pliers it will make the job easier, each clip you have to pinch to release each hose end , then make sure you put it back with the arrows pointing the right way
    Aberdeen
    I remember reading that you may have to bleed the system afterward s, is this true?
    Newcastle under Lyme
    should be able to fill the new filter up and reconnect. What little air is in the system would then be flushed out (If its the same canister filter I changed)
  1. 2.2 dti fuel filter change
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2012, 08:57
  2. Fuel filter change?
    By parky1 in forum Engine & Drivetrain
    Last Post: 13th August 2011, 22:24
  3. Fuel filter change
    By juggernaut in forum Engine & Drivetrain
    Last Post: 5th March 2009, 16:18
  4. How to change fuel filter?
    Last Post: 31st January 2009, 14:48
  5. 1.9 Fuel filter change
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 11th October 2008, 21:11
