Thread: P0606 3.0CDTi and no start
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default P0606 3.0CDTi and no start
    Turned the ignition on and the spanner light was on, also the ESP light was still on too? It normally goes off along with the preheating and ABS light.
    Ok I then turned the key normaly and when I thought the engine fired I released it. THE ENGINE STALLED IMMEDIATELY. This happened 3 times then I went to chech under the bonnet for a connector I've been fiddling with but that was fine. So I went back in the car to try and start it up again. Took the key out and then back in. The engine fired right up with no spanner light and ESP light. It then ran fine.
    The day before I got a message up saying a brakelight was shot so after I turned the engine off I pumped the brake pedal to see which light wasn't working. The pedal was stiff when I left the car. Is it connected?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    BUMP anyone? I'm worried it might be the fuel pump...what if the engine dies on the motorway at 70mph?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    really no1?
    Jun 2009
    South West
    Starting problem and esp light could be the CIM this is a common fault
    EVERYWHERE
    p0606 = faulty ECU ?
    Try disconnecting battery for a while.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The POS is fine. It did this only once.
    But why?
    Jul 2013
    Wakefield, West Yorkshire
    Vehicle : vauxhall
    Trim : vectra
    Engine : 2.0
    Quote Originally Posted by Celes View Post
    But why?
    Hi Celes, Did you manage to sort the P0606 code out as i have the same problem with the spanner light coming on but the battery light comes on as well. It runs fine but when i turn the engine off it won't start as it clicks as if its draining all the power and acts like the starter motor is stuck but it isn't?
    Any help would be most grateful
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by tidon View Post
    No mate. Thank god I sold that heap of steaming excrement before it exploded.
    Is yours by chance a manual? Could be that a faulty flywheel is causing the starter to fail to turn the engine. Or your battery could simply be dead. Check voltage when cranking the engine.
  1. 3,0CDTi SCV! Do I need to say more?
    By Eirik in forum Y & Z30DT Specific
    Last Post: 10th August 2012, 21:29
  2. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  3. 3.0CDTi de-cat
    By Celes in forum Diesel Engine related
    Last Post: 27th February 2010, 01:53
  4. 57 plate Vectra 3.0CDTi rubbish cold start
    By Celes in forum Engine & Drivetrain
    Last Post: 30th November 2009, 16:29
  5. Looking to get a 3.0cdti
    By sidvish69 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 19:58
