Results 1 to 2 of 2
Thread: Rear Blowers
    New Member zeffo1961's Avatar
    lincolnshire
    Default Rear Blowers
    Hi I've just fitted rear blowers to my 53 Vectra C. only to find when swiched on don't work.disconnected pipe to under dash outlet switched on no air comming out placed hand in outlet could feel trickle of air is this outlet blocked off and could anyone tell me how to rectify this as kids are fedup of melting in rear. cheer's zeffo
    Wales, UK
    Hi, I believe that the vecs fitted with rear blowers have an uprated motor, therefor a higher output to reach the back.
    I believe this was found out after someone else had retro-fitted one. You will need to replace the motor with one from a vec/sig with rear vents as standard.
    I believe the motor is located at the interior side of the bulkhead, sort of directly behind the radio !!!
    Hope this helps !! Sorry if its bad news !!!
  1. Rear blowers (Switch) not working
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2011, 11:36
  2. blowers
    By bown in forum Introduce yourself.
    Last Post: 9th November 2010, 22:42
  3. my blowers
    By stuee in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 12:39
  4. Retro fitting rear blowers in Sri, Any conclusion?
    By rik_t in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 17:24
  5. Any way of fitting rear blowers to Sri?
    Last Post: 13th June 2008, 16:24
vectra c rear blower
