Results 1 to 3 of 3
Thread: Automatic Wipers?
    Regular Member pauls898's Avatar
    Malvern
    Default Automatic Wipers?
    Since my car has had the roof lining out to have air bags replaced, I think that my automatic wipers are not functioning properly? Is there any easy way to test them? When its slightly driselling they appear just to work as intermititant ones, ie the speed between strokes appears to be constant and not on the amount of rain on the windscreen? If I fiddle with the switch on the stork I can speed them up and slow them down but the amount of rain on the windscreen doesn't seem to make any difference? Any ideas how I can tell if they have ******ed them?
    Paul
    Try using a plant sprayer bottle with some water in and spray the sensor... If you just mist the sensor it should just wipe once, try getting it really wet and see if you can alter the rate it wipes...
    The rain sensors don't like being disturbed... It took several visits to VX to get mine sorted...
    Malvern
    I sorted the fault myself, I found the worst, I removed the cover below the mirror and found that the fragile ribbon cable feeding the sensor had a spilt in it, as I thought must have got damaged when the repair centre removed the roof lining to replace the curtain air bag. I managed to solder the copper conductors back together, and hey presto they work once more
  1. automatic rain sensor wipers and lights
    By ADAM123 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2008, 17:20
  2. automatic rain sensor wipers and lights
    Last Post: 30th May 2008, 17:10
  3. Removing automatic windscreen wipers?!?
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2008, 02:12
  4. Automatic VXR anyone?
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2007, 19:54
  5. Automatic rear wipers
    By CBR600FV in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2006, 22:17
