Results 1 to 10 of 24
Thread: smell after turning AC off
    South East
    Default smell after turning AC off
    Car still has a newish smell esp. when hot. When I turn the AC on this new car smell gets better , but when I turn the AC off I get a bad smell that takes some time to get rid of
    Has had a new pollen filter any ideas. My B vec wasn't like this although I understand you can get a damp smell but mine is a bit toxic smelling.
    M
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    Switch off your A/C a couple of minutes before you end your journey as this helps. The smell is coming from dead insects and bacteria. Holts do something in their range as well. HTH.
    South East
    Cheers I do remember holts doing a bacteria cleaner but the smell can last for upto an hour so might give it ago.
    On the service information I did see that V/X had pumped something into it not that long ago.
    Regular Member Harry's Avatar
    Uxbridge, London
    i get this aswell, but its usually a vinegary type of smell, used to have this on my volvo s40 aswell. thought it was just a "feature" of AC.
    let me know if you get hold of that holtz stuff and if it works.
    I've used the COMMA A/C deoudoriser and anti-bac.. make mine smell sweeter..Simple to use and cheaper than VX doing it..
    lanarkshire
    would it not be better to just turn off fresh air intake into car 5 mins before leaving ?
    South East
    Quote Originally Posted by Harry
    Vinegary thats it
    Never had that before on any other AC car I've had.
    Where is the fan intake for the spray is it behind the glove box or do you spray it into behind the pollen filter?
    Uxbridge, London
    Quote Originally Posted by iceeee
    i'm curious...what difference would that make? i don't know what the cause is other than build up of muck in the pollen filter so how would it help?
    i expect cars to be able to function properly without user input. having to take precautionary measures in order for something to work as it should just doesn't sit right with me. i'm not naive enough to expect this to work forever, but with such sophisticated pieces of engineering i don't think it's too much to ask.
    don't get me wrong, i care about the welfare of my car, but to a certain extent.
    Sweden
    Smelly AC usually comes from the drain of the AC system being blocked ...
    This will cause bacteria in the system, and smell ...
    Uxbridge, London
    Is this easy enough to do or is this something that vauxhall technicians should undertake only?
  1. Turning Over
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 21st August 2009, 22:49
  2. The B is slowly turning into a C !! Another MOD!!!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2009, 15:37
  3. Looks like i'm turning.
    By shan in forum The 'Off Topic' room
    Last Post: 3rd February 2009, 13:55
  4. Turning your Wii 3d
    By rosssri in forum Games Room
    Last Post: 12th January 2009, 18:41
  5. Vectra not turning over?!!?!?!
    By djbasics123 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th October 2007, 14:23
