Results 1 to 10 of 11
Thread: Water leak from bulkhead??
    Jun 2009
    birmingham
    Default Water leak from bulkhead??
    After being out and about yesterday I noticed water on the floor under my 53 reg 2.2 dti sri. I only picked it up from the garage yesterday morrning after having the thermostat changed.
    Had a better look at it today and after the car has been running I get a considerable drip from a rubber plug/gromit on the bulk head. It is just to the left of centre. It is about 25 to 35mm long and cone shapped. The water is dripping from the end. Sticking a hand down it does feel as if it has a hole in the end.
    Does this have anything to do with the air con? I know air con systems drop a bit of water, but this is quite a considerable drip.
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Yes its the aircon outlet. I had this on my old veccy b, thought i had a leak inside the cabin until i discovered that outlet was blocked and it was running back into the car!... Its from where the cold air from the evaporator i think it is inside meets the warm air and the driplets form. they sit on a plate and are guided to the outside of the car via the bulkhead to that rubber pipe.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member pugs,signum's Avatar
    swansea
    Mine has started leaking this year and found its connected to the air conditioning, its coming from the same rubber peice that dap1977 said, i was wondering if the air conditioning was to have a re-charge (mine dont seem to get as cold as it used to be) would this solve the leaking?
    north east
    Is it not the kuttle panel drain ?
    have a look on the "Replacing pollen filter"how to thread how to clean it out.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    yes its the scuttle drain clean asap and rip the plastic out to keep clear
    Jul 2010
    Londonderry Northern Ireland
    its a common fault that these drains block up and the water overflows down through the heater and wrecks the motor/resistor
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    this thread mate is about the condensation build up which occurs via the aircon unit and then drips out from a little hose attached to the bulkhead and not the common scuttle panel problem which then causes water to leak into the car
    swansea
    Plasma is right, iv had the scuttle panel problem before so I know it's deffo not that!
    It was just a thought that the air con having a recharge might solve the problem? As the water will get closer to freezing and won't run out the pipe?
    Aug 2010
    Luton
    can some one post a pic of this then??
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by pugs,signum View Post
    Its not actual water which gets chilled its the aircon refrigerant. The water is purely condensation from the cold section which sits inside the car and mixes with warm air thus causing condensation which in turn drips onto a drip tray which then leads to the outside of the car, so in other words no. It proves that the air-con is getting nice and chilly for this to happen
  1. Water leak
    By Sike in forum Engine & Drivetrain
    Last Post: 10th August 2012, 17:16
  2. Water Leak
    By Sike in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2012, 14:42
  3. Water dripping from bulkhead after long drive with AirCon
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 14:49
  4. Water leak
    By Mark2.2 in forum Bodywork & Interior
    Last Post: 4th July 2008, 19:45
  5. Water Leak
    By acame2000 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2008, 10:17
vectra c forum water leak
indignia leaking bulkhead
water getting into my vectra c
water above bulkhead vectra c
vectra c leakedge ac in side cabin vectra c
opel vectra c air condition condensation exit
opel vectra c ac water in car
vectra c 2.2 dti water leak
water coming in vectra bulkhead
