Thread: Oil-can warning light
    Regular Member JET SINGH's Avatar
    NORTHAMPTON
    Default Oil-can warning light
    Quick question for u experts out there!
    My oil-can warning light keeps illuminating. It first came on whilst on the motorway doing 75mph during a long journey, then didnt c it again unless i was on a similar journey.
    Today, however, its come on again whilst driving through town.
    Have done the obvious and checked the oil level, which is fine!
    Car is a 2006 1.8SRi with only 20k on the clock (is due a service though!)
    Thanks in advance!
    Mileage : 000
    If it has an oil pressure sensor, that might be faulty.
    NORTHAMPTON
    Quote Originally Posted by ed taylor View Post
    Thanks Ed, is that pricey (no longer under warranty!!)
    And, do u think it'll wait until the service (booked for Thurs 9th July)?
    Mileage : 000
    I would have thought no more than say £20. If there is the correct amount of oil in the sump. You might as well wait. If you know where the sensor switch is then maybe change it yourself. You might be able to get one from a local motor factors.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    may need software update vaux have a cocern with 2008 model year if not could be level sensor which is in sump 2 hour job to change as sump needs to come off good luck!!!
    NORTHAMPTON
    Default Software update question
    Quote Originally Posted by paul wingnut View Post
    Well m8, cars just had its 20k service, n u were spot on...apparently needed a software update!!
    Just out of warranty, so cost me an additional £45.
    I tried to get the dealer in N'pton to meet me half way with £20 each, but he wasnt having it!
    Does anyone know wat else this ''software update'' does, n how it will benefit me/my vec?
    I was told it was neccessary, otherwise i wouldn't be able to trust the oil illumination light!
    Many thanks to all!
    Oct 2006
    ayrshire
    stealer are getting worse me thinks!!!!
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
