Results 1 to 10 of 11
Thread: Antifreeze change
    Mileage : 000
    Default Antifreeze change
    Thought I had better change the antifreeze in my motor. I put the VX long life in.
    Not too difficult a job. I removed the bottom hose, and flushed the old stuff out several times.
    Then put 4 Litres of anitifreeze in. As I live in a hardwater area. I put wait for it.........................Bottles water in to fill it up
    I also noticed that the filler cap was tight to remove. So here is a tip for you. Put some lubricant (I used back to black (a silicon) on the inside of the top of the headertank where the "O" ring locates. This made putting the cap back on easy and hopefully will stop it from seizing on.
    Now to give my motor a run and check the fluid level.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    If you live in a hardwater area and put 4L of AF in, why use bottled water?!
    Good job though and it probably a thing a lot of people do not think of doing regularly.
    Mileage : 000
    Quote Originally Posted by RobW View Post
    I thought it would be better for the cooling sytem.. If you saw how the kettle fir,s up with limescale. I was thinking bottled water would be better ( that is if it is not hard water).
    11 Post(s)
    Quote Originally Posted by ed taylor View Post
    The antifreeze has a corrosion inhibitor in it, so any old water will do.
    Mileage : 000
    Makes sence. and also easier for topping up.
    Regular Member dominic32's Avatar
    Oct 2007
    whitstable
    i always thought that neat anti freeze was best
    Mileage : 000
    Quote Originally Posted by dominic32 View Post
    No. I belive it can do more harm than good. Idealy it should be diluted 50/50 with water. Topping up should be the same too.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    im going to use distilled water,not too expensive and will be kinder to the engine in the long run,i also live in a hard water area
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Would a nice Australian red do the same Ed ?
    Mileage : 000
    Quote Originally Posted by FIL 4822 View Post
    I know a better place to put it.
  1. Which Antifreeze?
    By paz_badboy4life in forum Engine & Drivetrain
    Last Post: 26th September 2012, 16:02
  2. Antifreeze
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 23:21
  3. AntiFreeze
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2011, 14:18
  4. Antifreeze
    By ed taylor in forum General Chat
    Last Post: 26th May 2009, 21:42
  5. Antifreeze
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 19:38
