Thread: CDTi 150 Turbo issue !!
    Wales, UK
    Default CDTi 150 Turbo issue !!
    Havent long had my vec !!!
    First problem, sort of lol
    Drives fine, sounds sweet with no warnings but I put my foot down today and it didnt feel as quick. Ive messed about with it, and found that...
    Bear with me, as you accelerate, you can hear the turbo spool up and you can hear it die out where the most power would normally come in and the sound it makes when you back off (wastegate ??) isnt as harsh as it was ???
    It still pulls very well, but not like it did before !! Any ideas ??
    Thanks !!
    By the way, 2008 Vec, 15,000 miles !
    Wales, UK
    lololol
    Regular Member barkzz's Avatar
    Quote Originally Posted by mark_647 View Post
    Thanks !!
    Ive had a scenario with mine, where the Turbo spools up, and for a split second the power backs away, and then picks back up again. (Usually in 2nd or 3rd gear)
    I gave it a good "throat clearance" when the engine was at temp, and its been fine since
    Wales, UK
    Yer, sounds similar - it spools up, then you hear it back off where the full power would come. It doesnt pick back up though.
    Will give a good boot ago, cant do no harm !! lol
    Wales, UK
    Any other ideas people ? Thanks !
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Swirl flaps or EGR valve.
    If the turbos is whirring then it is fine m8.
    If either between the swirl flaps and turbo i hope its the turbo.
    Gazza4
  1. Z20NET oil issue after replacing turbo! :@
    By signumkid in forum Petrol Engine related
    Last Post: 5th December 2011, 16:06
  2. Turbo issue
    By kman247 in forum Engine & Drivetrain
    Last Post: 25th September 2011, 20:49
  3. 2.0 Turbo Rear Brake Pad issue
    By a1ant in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2010, 20:54
  4. Turbo issue???
    By duncatr in forum Engine & Drivetrain
    Last Post: 23rd December 2008, 14:10
  5. Turbo issue on 1.9 CDTI 120
    By RichieClyde in forum Engine & Drivetrain
    Last Post: 9th July 2008, 09:39
