Thread: Cleaned my EGR Valve today - did it need it?
    Regular Member Pete B's Avatar
    Malvern
    Default Cleaned my EGR Valve today - did it need it?
    I decided that at 3 yrs old & 48k miles (10k of them by me over 1 yr of ownership), I would dismantle & clean the EGR valve on my 150CDTi after reading all the threads on this site. I wasn't having any obvious problem and on removing & dismantling it, compared to some of the pics in other threads of similar valves at a range of mileages, it was a pleasant surprise.
    Sure enough, there was a thin uniform deposit of soft carbon over the insides of the valve body which was soon removed with a stiff paintbrush & white spirit. Similarly in the manifold bit, only a thin readily moved soft powdery deposit, nothing like the deposit shown here.
    When coming to the solenoid drilling/removal part, I observed the solenoid pin was free and moved readily without sticking in any position so I only sprayed WD40 into it a few times, then draining it out, no dismantling of the solenoid being required.
    There is no evidence that the valve has ever been changed before under warranty either on the Vx record when I got the car, the car service records or when speaking to the previous owner soon after I got it. I can only assume therefore that perhaps the kind of use the car had in its first 2 yrs before I had it was kind to the engine, lots of miles driven with the engine hot, little stop/start. The car had done 37k in its first 2 yrs & I was a little hesitant thinking it was a lot but perhaps now with this, it's better than 15k of short runs for things like this.
    So a good bit of preventative maintenance for another 20k or so, just hope the relatively clean state of these bits bodes well for the rest of the manifold. Putting it all back together, the car ran fine as would be expected.
    So, I was left thinking as to whether cars that have these problems early on have been used mainly under conditions which are less favourable to the engine or have I just been very lucky in having an unusually clean running engine?
    The only thing I regretted after was not getting the modified gasket set from Fiat.
    Winteringham
    whats the difference betwwen vauxhall gasket and fiat ?????
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by gregc View Post
    the fiat ones have got little holes in the gasket and not totaly open to reduce the build up of carbon.
    May 2006
    scotland
    Thats good news. I always use Millers in my diesel at each fillup. I too drive mainly a hot engine (not many stop/start journeys). Although I have never had the EGR valve off to check its state, the car drives like a dream (touch wood). An 04 Plate CDti (150), 36 k miles, BSR remapped past 13 months, had the car over 3 years. So hoping this is a trend.
    Malvern
    Quote Originally Posted by big rich View Post
    the fiat ones have got little holes in the gasket and not totally open to reduce the build up of carbon.
    As shown here
    The only thing I thought though is how long before those holes block up requiring gasket replacement ?
    Regular Member Ian's Avatar
    York
    I think that motorway / cruising driving is what causes the carbon to build up. When the car is at a steady speed, the engine doesnt need total fresh air so opens up the EGR V. When accelerating or driving more spritidly the engine needs the fresh air for more power and so closes the EGRV. what do you guys think?
    Feb 2007
    North west
    i would think the erg is to prevent high emissions and opens when the exhaust gas has unburnt fuel in.
  1. Juse cleaned EGR valve
    By Jonsey in forum Diesel Engine related
    Last Post: 19th January 2012, 12:16
  2. Cleaned EGR valve
    By Physmeister in forum Engine & Drivetrain
    Last Post: 1st May 2010, 10:23
  3. cleaned the egr valve today
    By peadar in forum Engine & Drivetrain
    Last Post: 13th January 2009, 14:42
  4. EGR VALVE and BOOST SENSOR cleaned today!
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 11th November 2008, 23:20
  5. Cleaned EGR valve today
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 19:14
