Results 1 to 10 of 19
Thread: Help!!! Petrol in Diesel vectra
    Ashford, Kent
    Default Help!!! Petrol in Diesel vectra
    today on the way to work stupidly i put BP Ultimat Unldeaded fuel into my vectra c 2.0 dti, i dident realise drove the car about 10miles then it started to act up was in a bad place to pull over so i keeped driveing car strugling more and more, today i have spent loads and loads of money clearing the unleaded out filled it back up with diesel tryed to get it to fire but wont, i took pip that comes from the fuel filter to the engine and filled it with diesel to get it to run through just will not start, if i put a drop of diesel directly passed the maf through the air intake i can get it to fire but very very smokey, have i done some seriouse damage, is the car saveable?
    Regular Member sristeven1's Avatar
    wirral
    think the whole engine needs flushing mate butr sure some one will tell you if thats wrong
    Regular Member kns's Avatar
    Northampton
    I know its not what you want to hear but I think you may of F***k your engine.
    what year is your car ?
    how much petrol did you put in?
    Plymouth
    I would of changed the fuel filter as a matter of course too
    How much petrol did u put in... how much diesel wa sin ur tank?
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    oh unlucky mate thats something we all hope never happens to us
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Be careful whatever ya do. The pumps on the DTi's can be fragile. If you have taken a pipe off chances are that the fuel system will need the diesel bled through. Be warned though that the dti's are not self bleeding and you will need to use a bulb pump or similar to bleed diesel through. If you are not sure get a garage to do it
    Stockton on Tees
    Its never happened to me before but i'm sure when i've spoken about it to others who have (not sure if petrol in a diesel or vice versa) the petrol could damage the seals etc inside the engine so it can be a costly fix. Do the Vec DTi's not have a pump on them. i've never looked on mine but my Fiesta TDCi had a hand pump to bleed diesel through.
    Ashford, Kent
    50% of a tank of petrol, to about 2% of diesel.
    and the tube that goes directly to the engine ive taken the fuel pump and filter out of the eqation. by letting the engine pull the diesel in itself, and still no response.
    Regular Member fingers66's Avatar
    Carpe Diem
    I did exact same as you m8, .... my old 2DTi at the time, wouldnt start at all, ended up getting towed for about 500 yards to get it to go..... loads of black smoke, but after wee while all was fine..... went on to do another 50K miles after that with no problems.
    Ashford, Kent
    well hope its ok, we spent a good 2 hours trying to start it got it started a few times but only by putting diesel into the air intake like i said, also ive been putting the diesel directly into the engine through the feed from the fuel filter, it sucks it in had it on jump leads and keeped trying to start with 15 second breaks for about 40 - 1hour and nothing at all
  1. Swap petrol to diesel, Vectra to Signum, Elegance to Elite
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2012, 20:26
  2. Petrol or diesel
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 14:11
  3. Diesel Vectra, Petrol Damage?
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2009, 18:42
  4. Buying a Vectra: Petrol or Diesel?
    By L11Marc in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 18:48
  5. Buying a Vectra: Petrol or Diesel?
    Last Post: 13th July 2008, 15:37
