just changed my rear brake pads but now the brakes r **** and very soft .no fluid escaped when i done them and it dont feel to safe to drive to bed them in !!
bleed them
They might just need to bed in for a while?. Where they VX pads.
If they were a "cheaper" brand. They might need to bed in. Is the pedal travel the same as before. It should be, as you have not lost any fluid. How bad are they?.
Did you press the brake pedal several times First. before you pulled the handbrake up seveal times. After you put it all back together.
The brake fliud will go up as you have put new pads in.
