Results 1 to 10 of 20
Thread: Oil change
    Newcastle under Lyme
    Default Oil change
    Where is the oil filter located. As I couldnt find anything from a search. Qite surprised there isnt a how 2 for an oil change. Would it help anyone if I put it together
    Regular Member neilybhoy1888's Avatar
    caithness
    wot engine is it mate if its a derv its down the back of the engine under the manifold i beleave
    petrol
    Mileage : 000
    Whilst my engine is totaly different to yours. Mine has a replaceble filter. It is in an ally "can" on the front of the engine, It is a lot smaller than the screw on filters. Also it has a large hexogon to undo it with. Maybe yours is simalar.
    looks similar to this but not as fat.
    https://www.rapidcarparts.co.uk/show...if&w=280&h=233
    What tool do you use for removing the Hexagon?
    No matter thats easy to find
    Mileage : 000
    Might be a 24m/m hexogon.
    yeah think it is looking at the highest 22mm bit I have. doh. Off to the motor mart now! Also what size hex is the sump plug?
    Mileage : 000
    It might be a Torx you need. Not a socket. I forget the size of the Torx though.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
