Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Gone and done it - BSR PPC remap - Should have done it long time ago.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Talking Gone and done it - BSR PPC remap - Should have done it long time ago.
    After much umming and more umming I went and did it, I got the BSR PPC stage 1 remap for my 67k 55 plate CDTI 150.
    Once I had downloaded the current software onto the PPC I flashed my ECU, took about 1.5 mins.
    No need to disconnect battery etc as any data on your engine gets wiped so you start afresh.
    Started up no problem, left it ticking over for a few mins before going out.
    took it gently for the first minute then gradually tried it out.
    Very noticeable power hike at 2500 rpm, if anything too violent and not nice to drive, but fun all the same, but the next day I got to open the engine up a little and took the revs up to the red line.
    It pulled very well and hit the red and limited at 5000 rpm, about 150 less than my original map, not really a problem as I don't drive it up there that often.
    What it did do though is smooth out the whole map due to the ECU adapting which has now left the car soo much better and smoother, the violent pickup has gone replaced by just sheer pull all the way from tick over and continuing strong all the way up to 4500 + rpm.
    The economy is slightly better when driving normally and their is no flat spot below 2000 rpm, the car just pulls smoothly and noticeably better.
    It should have been like this from the factory.
    Booting it does produce some smoke now, but hat is to be expected but it is not too excessive.
    I have a long run 1000 miles next week to Poland for a fortnight so I will have a better idea of how much difference this remap makes.
    I will post my findings on my return.
    But first impressions are good, I know it costs a fair bit, but I still wish I had done this ages ago.
    P.S. The Continental Sport Contact 3's are now the limiting factor.
    Regular Member collow123's Avatar
    cumnock ayrshire
    Post up your finding after next week mate it will be good to hear how it went on the trip. I've only ever heard good reports about bsr remaps. Have a good trip and i hope you get to put the foot down.
    Regular Member fishaman's Avatar
    dunston,gateshead
    good look with the trip,how much did the remap cost if you dont mind
    Regular Member AdeyCorp's Avatar
    Chesterfield
    Sounds good, wish I had brought a CDTi.
    Feb 2007
    England
    Quote Originally Posted by Chocki View Post
    I wonder why they don't make 'em like that from the factory?
    Winteringham
    Smoke should go after about 1k miles if not give egr a good clean
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i want mine doing eventuly, sounds like a must have mod
    Stockton on Tees
    I'm not to good with this re map stuff so just a couple of questions! You say you Flashed the ECU with the software you down loaded. Does this mean you have the data to Flash as many ECU's as you want?? If so i'd start flogging ECU Flash's!!! Thanks and i hope you enjoy your new found power!!!
    Jul 2006
    Wolverhampton
    The BSR PPC kit comes with a ECU flasher, but it is coded to your ECU only so you can't use it on another car.
    I got mine from LMF and it came next day and it's over £500.
    Apparently the unit has multiple maps once you've downloaded, but only loads the map specific to your ECU, based on what's already in there or something like that when you read the manual.
    May 2006
    scotland
    Yes mate, good result. I have had mine for 13 months now (BSR) + KN panel filter. I was a bit perplexed to read the bit about the violent pickup as mine never exhibited that from the word go, I have described mine as smooth as a V engine with the remap but glad to hear once yours had re-learned, this has gone. I luv just a progressive gentle throttle application with this map, its like a jet airliner going up hills as it accelerates. Enjoy. Note your smoke, try millers in your diesel at every fillup, should get rid of much of this.
  1. For once in a long time both cars are clean at the same time!!!
    By ijk571 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 10:40
  2. Long Time Looker, First Time Poster......
    By Whisky in forum Introduce yourself.
    Last Post: 26th March 2011, 22:37
  3. Long time looker first time poster
    By robg8070 in forum Introduce yourself.
    Last Post: 6th December 2009, 11:51
  4. Long time lurker, First time poster!
    By Crumpster in forum Introduce yourself.
    Last Post: 22nd October 2006, 07:47
  5. my favourite 'pop' video for a long long time
    By Andy in forum General Chat
    Last Post: 18th January 2006, 02:45
