Thread: Drove through a flood, how do I clean the rad now?
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Default Drove through a flood, how do I clean the rad now?
    On the way home from work, the rain was torrential with flooding.
    I had no choice but drive through a flood, very carefully, there were a few cars drowned and smoking (Steaming) at the side of the road, I just crawled through whilst allowing the clutch to slip a little and keeping the revs up a bit.
    Now my rads are full of leaves and mud and faeces (Oh yes it smells!). The engine temperature is about 10 to 12 deg hotter than standard.
    I tried a high powered hose through the open grill but it will not shift the blockages.
    Any ideas anyone?.
    The car is a 150 CDTi facelift so only the bottom section of the front grille is open, and this was under water!!!.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Stop it with the Pressure hose mate. That will only make it worse. Pressure washers can easily bend all the fins, there was a thread ages ago about this very thing. I'd let it dry out and doing this will naturally shrink any debris, then blow it out with an air line.
    Jul 2006
    Wolverhampton
    That's aright, I didn't use a jet wash, just the normal garden hose with the nozzle adjusted to jet.
    I'll check it again in the morning after it's had time to dry.
    Thanks.
    Now, where do I get an air line, do you reckon vacuum cleaner might do it?
    Regular Member Readster's Avatar
    Plymouth
    Try the tyre airline at a garage forecourt.
    Gently bentley with your radiator whatever method you use to clean it.
    11 Post(s)
    You could try soaking the crud out. Instead of a pressure hose, just a normal one running at low pressure and slowly dissolve the mud.
    The leaves will eventually dry out and rot away.
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    whatever you do, Dont use compressed air or high pressure water !!!
    Soaking in water is the only way to "Safely" unblock you're radiator.
    Best bet, If you can is to remove the radiator and leave it soaking over night.
    Rubbin'z racing Harry!
  1. Vectra in flood
    By Craig1985 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 1st May 2012, 15:41
  2. had a flood!
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2009, 20:38
  3. Flood water.....
    By signum_1.9 in forum Diesel Engine related
    Last Post: 8th July 2009, 16:49
  4. Billing flood watch...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 20:31
  5. Engine flood damage!
    By John Arthurs in forum Engine & Drivetrain
    Last Post: 16th January 2007, 12:35
