Results 1 to 10 of 23
Thread: car and spanner symbol
    Jun 2009
    notts
    Default car and spanner symbol
    Been on holiday in wife's 2004 signum 1.9 cdti 150
    Weather has been hot this week, 25'c
    In the morning when car cold and only at this time, a symbol of a spanner and car has come up on dash. For 1 minute only. Then goes out, car runs fine. 45mpg, so not affected that. Been doing 200miles per day while away. Book says auto transmission/ engine elec fault/ diesel water in fuel filter. Assume it's the last one.
    Condensation?
    Any other idea's?
    Will it stop, Do I need to book it in at stealer? Is it ok to run?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    as long as the symbol on the dash goes out bud its fine if not you have a problem
    Regular Member Harro's Avatar
    Jan 2008
    York
    I think its just telling you there was a fault but not anymore. Should stop doing it after a while.
    preston
    Exactly the same symptoms as my 1.9cdti and turned out to be glow plugs.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Its reporting that there has been a fault that has produced a code - which is now stored.
    If the spanner light goes out - its just a stored code and the fault is currently not present
    If the light stays on - fault currently present.
    Get the code read and see what it was... I had the spanner light not so long ago flash on then off.. fault code was an information code on the egr valve movement - hasnt happened again since I cleared it
    Jun 2009
    notts
    Car been to dealer, £54 for diagnostic check. Fault seem's to be glow plugs, They want £300 to replace, Is there 1 per cylinder?
    Would they be covered by warranty? (she said she would find out)
    Is it worth getting them done at another local garage (price)
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Quote Originally Posted by raddish View Post
    £300 to replace glow plugs now thats an absolute rip off.... pretty easy DIY job. there are 4 to change and takes about 30/45 mins. Same as changing spark plugs on a petrol car. Just unplug elec connector on top, then using correct socket unscrew glow plug keeping it straight and not pounding on so it dont snap. Then fit new.
    I had one glow plug that wasnt working on my 1.9 16 valve engine, the cost was £14.40 for a new one from my local Vauxhall dealer. It took all of 5 minutes to remove the old one and fit the new one. The price you have been quoted seems a bit over the top even if the dealership was including the control relay for the glow plugs as well.
    Jun 2009
    notts
    4 glow plugs fitted £154. The check was under warrenty.
    Problem, Wife picked car up. 1/2 home symbol came back on, car as no power, will only rev to 3000, sounds like no turbo, feels like it too. What have they done?
    Also the washer jets don't work now, look like they've been pushed down, and black cover is loose.
    Well I guess you or your wife will be going back to see them today then. It looks like your car did not even get taken out on the road for a test drive after they had finished replacing the glow plugs.Crumbs that was a crazy price to charge for that job.
  1. spanner symbol
    By tecg in forum Engine & Drivetrain
    Last Post: 27th May 2012, 19:39
  2. car/spanner symbol
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2012, 09:00
  3. Spanner symbol up???
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2010, 22:43
  4. car with a spanner symbol
    By ric85 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 18:07
  5. car symbol with spanner
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2008, 21:53
vauxhall vectra car spanner only goes off when car is started
vectra c 1.9 cdti symbols
how do I get rid of the spanner symbol on my vectra c
