Thread: Aircon condensors 1.9CDTi and 2.0DTi are they the same?
    Regular Member Little John's Avatar
    North West
    Default Aircon condensors 1.9CDTi and 2.0DTi are they the same?
    I wasnt quite sure about putting this in here as there isnt a technical section for HVAC.
    I need a new condensor for my 1.9CDTi I have been to the VX dealer and they want a small fortune so I searched the net and found a company selling them for about £100 I then thought about local motor factors incase it goes wrong and they all seem to be comming back saying they either don't have the part or can't find it listed then asking me if the 2.0DTi is the same part, if I don't know then they need a number off the part or somthing so they can check it out and find a compatible unit.
    I don't fancy takeing the bumper off to find any identification numbers, refitting then waiting for the part and all that goes with it.
    So does anyone know if the 2.0DTi air con condensor will fit on the 1.9CDTi?
    Birmingham
    As far as I am aware, NO!
    I had to replace the RAD's on my dad's CDTI 150 about 2 years ago and my mate who used to work at Vx then said they were different.
    Actually, I was told the "whole pack is different and the part codes are differnt", so didnt take a chance.
    I simply took his word for it, so would assume no.
    Please dont hold me to this, someone will confirm shortly hopefully.
    Bye bye Vec B
    - Hello Siggy!
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    Vaux_Man is correct they are different, probably have differing mount points and such. If you look on ebay (will try to find a link) there is a seller on there selling for approx £100 plus £15 p&p.
    edit. found the link for you - http://cgi.ebay.co.uk/COMA-SIGNUM-VE...%3A1|294%3A200
    as Tadpole would post....
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    For 1.9 engines Z19DTL, Z19DTH, Z19DT manual or auto use condenser assy (with dryer) 13114943.
    For 2.0 engines Z20NET manual use condenser assy (with dryer) 24418364
    For 2.0 engines Y20DTH manual use condenser assy (with dryer) 24418363
    Hope that helps.
    North West
    Thanks for the info, I have the OE number that they want so I will give them that and see what they come back with.
  1. 1.9cdti vs 2.0dti
    By Ace1981 in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2012, 21:11
  2. Silencer from 1.9cdti on to a 2.0DTi
    By Jonsey in forum Diesel Engine related
    Last Post: 7th February 2012, 13:00
  3. 3.0dti twin exit on a 1.9cdti?
    By thunderpantz in forum Engine & Drivetrain
    Last Post: 12th September 2011, 19:49
  4. Replies: 5
    Last Post: 3rd May 2010, 19:17
  5. will discs pads callipers etc from 1.9cdti fit 2.0dti?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 20:04
