Thread: Correct Power Steering Fluid ?
    Northants
    Default Correct Power Steering Fluid ?
    Hi, mislaid my owners manual and need the correct spec of PSF for my 2.0 DTI. I thought it was generic but a quick pop to halfords and found dexronII, dexronIII, ford spec, halfords generic...?
    Any advice please?
    Regular Member ptrehearn152's Avatar
    norfolk
    most power steering fluid is just auto transmission fluid, the numbers after the dexron (II/III) are usually upgrades so III is an upgraded II. should tell you in the handbook if not go to a car accessory shop and they should have a catalogue and be able to recomend correct gade.
    Bristol
    Vehicle : CDTI 150
    According to TIS requires EHPS (Electro Hydraulic Power Steering) fluid, Either 725ml if the compact EHPS or 905ml if standard
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    CHF m8,central hydraulic fluid, and its green, so when you get some ask for green psf
  1. Correct power steering fluid for vvt compact EHPS?
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2013, 17:25
  2. Power steering fluid.........
    By Sway in forum Engine & Drivetrain
    Last Post: 18th December 2012, 20:06
  3. Power Steering fluid
    By Dazbaz in forum Engine & Drivetrain
    Last Post: 21st August 2009, 17:03
  4. power steering fluid ??
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2006, 17:14
  5. Power Steering Fluid
    By MLC in forum General Chat
    Last Post: 28th June 2006, 13:09
opel vectra c steering fluid
vectra c power steering fluid
