Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: CDTI 150 Manifolds
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Default CDTI 150 Manifolds
    Guys need some help here have Vx released an updated Manifold ofr the 1.9 CDTI 150?
    Could I have part numbers please for both parts if there has been a release.
    Also on what basis have vx replaced the manifold at their expense?
    Regards,
    Gazza4
    May 2006
    scotland
    Sorry, do not personally have the details to answer your questions but to my knowledge there is an upgrade to cope with the older feable swirl valve design but I think it is up to the individual to cough up for this upgrade post warrenty.
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    Manifold wont be changed post warranty you need to get it done before the warranty runs out, best you can hope for is if you have a full Vx service history is then a contribution towards it.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    There was a pdf posted a bit back with the pierburg update information regarding the 'new' inlet manifolds. As said above, they will only be changed under warranty (providing a problem was found of course).
    I'll have a quick look and see if I can find it....
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Yes - the 'revised' inlet has better swirl flap bearings to stop the up and down movement on the flaps which in the end wears the ball joints and caused the rod to pop off.. This also causes the swirl flaps to gum up.
    Part numbers here when my inlet and all ancillaries were changed:
    actuator for swirl valve 55199915
    Thats the one..
    Parts when VX did mine:
    93191278 - Rngine Timing Parts Kit
    55210201 - Inlet manifold
    55199915 - Bracket (Actuator)
    93179058 - Gasket
    55215031 - EGR Valve
    93181665 - Gasket
    93178885 - Gasket
    93170402 - Anitfreeze
    Hope that helps
    Middlesex
    Trim : SRI
    Mileage : 100k
    some old and new pics for you from my previous thread on this:
    "Took some nice pics today of my new shiney one:
    You can see the new Swirl Tops and Rod here:
    ..and here - note that the Swirl Tops are slightly different - they dont have the hole in them
    See:
    Old Inlet:
    Rod was very easy to put on and off so no wonder it fell off easy.. it hardley grips.. I can see now that a washer would be quite a good fix for the rod I think.
    Showing here one of the many issues with the old inlet.. The swirls move up and down too much aparently.. this causes the wear on the ball joints etc and cause the rod to come off... Also effects the swirl operation etc...
    Interesting eh! lol
    A "
    Anthony
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers guys much appreciated.
    Just need to know if vx have released one and its not hearsay.
    Gazza4
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by AntSSSS View Post
    Thats the one..
    93179058 - Gasket
    93181665 - Gasket
    93178885 - Gasket
    Hope that helps
    already answered that mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers Antssss.
    Got the two part numbers: the new one as mentioned above and the old inlet manifold is 55194739
    Gazza4
    Regular Member installer's Avatar
    Nottingham
    Was put into production from 2007 feb - final revision on manifold etc according to TIS
  1. Vectra C exhaust manifolds
    By paul667 in forum Tuning
    Last Post: 20th May 2013, 16:09
  2. z18xe astra/vectra manifolds?
    By Dose in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2009, 21:19
revised inlet manifold for a 1.9 cdti 150 vectra 07
