Thread: Strange noises from front left hand side
    Jun 2007
    Kilmarnock
    Default Strange noises from front left hand side
    Hi all,
    Just noticed a strange sound coming from the front left of my vectra GSI. Its an irreegular "ticking" sound almost like small stones hitting the underside of the car.
    Had a look underneath but can;t see anything obvious. Haven;t had a chance to get wheel off yet but is there anything else i can check?
    Can't see anything wrong with spring (only replaced originals with eibachs about a year and a half ago).
    Doens;t seem to be any handling issues but very annoying.
    Thanks for any help
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    You could check the centre exhaust heat sheild, may have corroded through and come loose (mine did).
    Is it an Auto or Manual 'box? I've a 3.2 Auto Elite and get a noise a bit like that at times and I've put it down to a feature of the box.
    Jun 2007
    Kilmarnock
    Its a manual box (3.2 GSI). HAven;t noticed it before but i did recently have one of the flex joints replaced as it was corroded but this is on the RHS.
    Heat shield might be it. sounds almost like tinfoil "crinkling" if you know what i mean?
    I'll have a look tomorrow
    Thanks for your help
    Stockton on Tees
    Also check the brake disc protector on the inside of the disc. It can also catch the disc but usually makes a squeaky noise. Worth checking just in case.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Have you checked the tyre, sometimes a piece of metal stuck in the tyre can cause a ticking sound like that.
    Jun 2007
    Kilmarnock
    Thanks for all the replies. Seems like it was just the heat shield. Pressed it back into shape and noise has gone. I did notice the centre nut looks a bit loose (heat shield moves up and down over bolt) so i'll need to get under to try and tighten this as well.
    thanks again.
    RoddyKFC
  1. Strange noises when warm
    By sparky1292 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th October 2012, 06:56
  2. Strange noise from front left going downhill
    By thegoldenbullet in forum Vectra C / Signum Troubleshooting
    Last Post: 29th April 2012, 22:21
  3. Strange noises
    By Vectra49 in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2010, 17:15
  4. siren in boot left hand side
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2009, 01:35
