Thread: Juddering at 200 rpm??????
    Regular Member raymie.d's Avatar
    Feb 2007
    Glasgow
    Default Juddering at 200 rpm??????
    I have a problem with my 1.9 CDTi (150). Since it came back from its last service it has been juddering/kangarooing at or around 2000-2500rpm. It doesn't do it all the time, if I am accelerating hard it doesn't happen, only when I am driving normally. It happens in all gears but it only happens when the engine is warm? and no fault codes.
    I have tried taking the 3rd injector off and on again to clear corrosion and have also cable tied it hard on. My air conditioning was working fine as well but it has stopped getting cold. Could the two be linked? i.e maybe something has hit the condenser and intercooler?
    Any help would be most appreciated.
    Feb 2007
    Glasgow
    Anyone?
    Regular Member ptrehearn152's Avatar
    norfolk
    if it didnt do this before the service i would take it back, wild stab in the dark, if they have replaced the fuel filter maybe incorrectly fitted and drawing air or injector pipe loose, check for fuel leaks. just for starters.
    Aug 2007
    bournemouth
    If it feels like you're driving over a cobbled road it could be the DMF.
    Feb 2007
    Glasgow
    Its more like kangarooing but only for a split second then its okay. One of my friends who is a mechanic said to bleed the fuel filter as it may be an airlock. How do you bleed the fuel filter and where is it? I am quite good at mechanics but I dont know where the filter is?
    Full Member spennny's Avatar
    Blantyre
    Dunno if its the same position as the 2.2 direct, look inder the rear passenger door, drivers side, you will see a can like thing there, thats it....... there are 2 clips on each side of it , you have to push them in to release and pop off.
    Regular Member scottyd's Avatar
    paisley
    take it back and get them to fix it if it needs bled its upto them to do.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    take it back
  1. juddering
    By scottsabs in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 12:59
  2. Juddering
    By sebadee in forum Troubleshooting
    Last Post: 18th March 2011, 15:08
  3. v6 juddering
    By jasv6 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 21:13
  4. Juddering
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 26th April 2010, 22:17
  5. 2.0T Juddering
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 7th October 2009, 11:56
