Thread: My rear washer works.........
    Regular Member Messenger's Avatar
    Hampshire
    Default My rear washer works.........
    but only when stopped and the ignition has just been turned on. It also works when reversing but not moving forwards The wiper works without fault so its only the washer thats causing grief
    Any idea's please, its still under warranty but thought I would ask here first
    Thanks for any help
    Oct 2006
    southampton
    15 Post(s)
    Dont know if you know this but if you have your front wipers on and not your rear it will automatically wipe the rear when selecting reverse.
    Hampshire
    Quote Originally Posted by lizard View Post
    Thanks yes I knew that but the problem is the washers the wipers work just fine in all operations. I just can't figure out why the rear won't wash when moving forwards and only when parked or moving backwards.
    When parked the washer motor runs and the washer works and also in reverse BUT the motor won't run when the car is moving forwards????
    The front washers work fine in any direction.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
  1. Rear Washer jet
    By Vectra-c-SRI in forum Bodywork & Interior
    Last Post: 30th January 2013, 01:04
  2. Rear washer jet.
    By burbling1 in forum Bodywork & Interior
    Last Post: 8th November 2012, 22:22
  3. Rear Washer
    By Carl83 in forum Bodywork & Interior
    Last Post: 22nd September 2011, 19:21
  4. rear washer jet
    By bret.c in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2010, 15:04
  5. Rear Washer.
    By ashdog in forum Bodywork & Interior
    Last Post: 27th August 2006, 07:43
