Results 1 to 10 of 22
Thread: Going to clean the EGR Valve this weekend.....Question's
    Birmingham
    Default Going to clean the EGR Valve this weekend.....Question's
    Guy's,
    Im planning on cleaning out the EGR Valve on my dads CDTI SRI 150 this weekend.
    I have already bought the gaskets and have plenty of spirit (parrafin) to clean the EGR Valve with.
    Anything special I need to do or take care with?
    Also, what do I clean the engine side of the EGR Valve with?
    Any hints and tips will be more than appreciated.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Remember to clean the boost sensor too .... gentle with carb cleaner
    Birmingham
    Quote Originally Posted by steve View Post
    Where is this?
    Bye bye Vec B
    - Hello Siggy!
    Nov 2007
    think on the CDTI its near the back right of the engine....
    here is a pic
    Its the little yellow/orange sensor in the cone that needs cleaned...
    You'll probably find you cant see the sensor because the cone is full of gunk...
    So just remove the one screw that holds the whole thing to the engine,unclip elec cable, pull out the part show above (its got a rubber seal on so make need a gentle tug)
    Clean and refit
    HTH M8
    North East
    Steve,
    Can this booster sensor be removed without removing the EGR? The reason I ask is I cleaned my EGR about 2 months ago but didn't know about cleaning this sensor.
    Michael
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Does anyone know how much these boost sensors are new..?
    Nov 2007
    Quote Originally Posted by mpc View Post
    Steve,
    Michael
    Yes defo its a seperate external part... super easy job
    Birmingham
    Cheers Steve for all your help. Hopefully I will get it done this weekend!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Yep there about £44 as i enquired about one for mine but in the end turned out to be a disconnected vacumm pipe.
    North East
    If I take this sensor of to clean will I get the yellow spanner light on the dash on startup after refitting, also is it just the "yellow" part that needs cleaning and do I need to be careful with it, i.e. what do I clean it with, could i just spray it with a aerosol?
    Michael
  1. will a egr valve clean help my mpg?
    By will-crowe in forum Engine & Drivetrain
    Last Post: 14th December 2012, 11:24
  2. Replies: 17
    Last Post: 19th July 2012, 19:29
  3. clean for her weekend away
    By ditchp in forum Detailing and Car Care Discussion
    Last Post: 24th June 2010, 19:40
  4. EGR Valve Clean-WHAT TO DO???
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 13:19
  5. Weekend Clean
    By Elite2.2DTi in forum Gallery
    Last Post: 24th March 2007, 17:17
