Results 1 to 10 of 10
Thread: check safegaurd problem
    Jun 2009
    WARWICKSHIRE
    Default check safegaurd problem
    i tried to fit hid lights and like a burke my battery went flat. I:m not sure if it was fiting the lights and taking them of because they didnt work or killing the battery but now i get this check safebaurd anyone tell me how to get rid of this warning
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    "Check safeguard" is refering to an alarm fault. If the power sounder has internal back up batteries, then they may well have also gone flat with the main battery, and will take a little while to recharge and then the message *might* disappear. Ultimately though a fault code readout will tell you what fault(s) there is with the alarm.
    Jun 2009
    WARWICKSHIRE
    i'm not geting any errors codes and had the battery checked today for voltage and its fine its been like it now for a week
    Oxfordshire
    13 Post(s)
    Engine : 2.0 CDTi
    Year : 2013
    The main battery might well be fine, but if the power sounder has an internal battery, then that could well be the problem. It's not uncommon.
    What you using to read the fault codes out? With the "check safeguard" message, there should be some fault codes stored.
    Regular Member JSYSH466Y's Avatar
    Newcastle under Lyme
    only takes 30 mins to fit so I doubt your battery would die that quick unless its in bad shape
    Blantyre
    Silly question here mate but have you checked your fuses .......
    Jun 2009
    WARWICKSHIRE
    funny i was thinking that today because when puting my hid lights in i thought my fuse for indicators went so i pulled a few out to check then may have disturbed one will check 2morow ..cheers
    Jun 2009
    WARWICKSHIRE
    spenny you were right it was a fuse cheers mate
    Regular Member denzilbud's Avatar
    May 2009
    cambridge
    which one
    Blantyre
    Quote Originally Posted by luckyjohn99 View Post
    Was i
  1. ABS Cable problem(Continuity Check)
    By Blade1000 in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2012, 21:21
  2. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  3. Safegaurd
    By sb1uk in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2011, 23:22
  4. safegaurd = ???
    By bradley in forum Diesel Engine related
    Last Post: 23rd December 2009, 19:46
  5. check safegaurd
    By adfrodsham in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2009, 12:28
