Thread: water in foot well
    New Member muller73's Avatar
    warrington
    Default water in foot well
    my veccy has a water ingress in the n/s rear footwell carn't work out if its from rain or water from road!! i'm startin to guess it from the rear tailgate is i've had it on the ramps underneath is sound.
    Moray
    Quote Originally Posted by muller73 View Post
    Had the same problem m8, sounds like a water drain valve is blocked down by your pollen filter.
    Lift the bonnet and remove the rubber seal infront of the windscreen, lift up the plastic panel to reveal the pollen filter and if im correct that area will be floded with water, there is a small rubber drain on the n/s just pust your fingers through it to clear it and replace your pollen filter.
    Hope this helps
    Mileage : 000
    Have a look here for the pollen filter.
    Regular Member woodaj's Avatar
    Crewe
    Quote Originally Posted by veccysri150 View Post
    Hope this helps
    Had the same problem and this worked for me. then just run around with the heater on full balst to dry it out
    Regular Member Dezza's Avatar
    Glasgow
    Not sure if the vectra is the same, but I had this problem on my last car. Turned out to be a ripped vapour seal inside the door. Rain water was dripping into the car instead of running into the drain at the bottom of the door.
  1. water in passenger foot well
    By crayon in forum Bodywork & Interior
    Last Post: 28th January 2011, 13:31
  2. water in passenger foot well
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2010, 16:39
  3. There’s water in the passenger foot well
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 22:36
  4. water leak in n/s/f foot well
    By vectra 1985 in forum Bodywork & Interior
    Last Post: 26th February 2010, 22:38
