Results 1 to 10 of 16
Thread: gearbox removal
    wirral
    Default gearbox removal
    hi all
    anyone know what the easiest way to remove the gearbox from a 2002 vectra 1.8 16v
    am going to replace clutch on my brothers vec c at weekend and wondering any hints or tips
    also what oil should be in the gearbox
    hope someone can help any info would be great
    thanks lee
    Newcastle under Lyme
    Cant help on this. But how did the wheels fit
    wirral
    Default wheels
    havent had a min to fit them yet m8 been busy at work and doin a few jobs hope 2 fit them fri or wkend
    let u know
    Regular Member garvey's Avatar
    Co Durham
    All I can say is enjoy
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    hello mate best way to do is take out batt box to get at top bolts and top mount get car on axle stands drop front pipe drop bottom ball joints and anti roll bar links pull out shafts loosen bolts on o/s frame leave in couple of turns take off gearbox rear mount support n/s frame take out bolts and drop frame on one side them box will come past .. hope this helps !!!!!!!
    wirral
    thanks just what i thought wasnt sure if subframe needed removing to get box out
    thanks again
    Quote Originally Posted by paul wingnut View Post
    If only it was as quick to do as reading the how2 ................
    durham
    yeah you right not a bad job on the 1.8 tho i would do one of them than a cdti anyday ..
    wirral
    u know wot the oil is in it?
    Bristol
    Vehicle : CDTI 150
    TIS only gives the Vx pt number, but the F17 gearbox takes 1.6 litres of it.
  1. M32 gearbox removal
    By Aikon58 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 21:03
  2. Few questions around gearbox removal
    By Gavin2.6 in forum Engine & Drivetrain
    Last Post: 27th January 2012, 19:24
  3. 2.2dti gearbox removal
    By truckdoctor in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2012, 18:08
  4. f40 Gearbox removal help wanted
    By steve alan in forum Engine & Drivetrain
    Last Post: 18th December 2010, 17:44
  5. 2.0DTi Gearbox Removal?
    By british_bulldog in forum Engine & Drivetrain
    Last Post: 15th November 2010, 21:02
https:www.vectra-c.comforumshowthread.php85810-gearbox-removal
insignia gearbox removal
can you get the gearbox out on insignia without taking subframe off
f40 gearbox removal
o4 vectra diesel gearbox removal
opel zafira dti gearbox removal
best way to remove insignia gearbox
2008 vectra gearbox removal
vectra c gearbox do need to remove subframe
How long does it take to change a gear box on a vauxhall vectra
how to remove gearbox vectra c
vectra m32 gearbox removal
vauxhall vectra c 1.8 2007 change gear box
how to tell if insignia gearbox is on way out
vauxall corsa c gearbox removal
open insignia gearbox removal
how to remove subframe vauxhall vectra auto
vectra cdti 150bhp gearbox removal
vectra c f17 clutch change guide
vauxhall vectra c gearbox removal
Opel vectra c gearbox removal
vectra c gearbox removal guide
signum gearbox removal
vectra c clutch change guide
vauxhall astra h f17 gearbox removal
