Thread: TPMS Reset??
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default TPMS Reset??
    Anyone in the TPMS club know how to reset TPMS..
    I've moved a front wheel to the rear and it's still showing as a front tyre in TPMS. I've disconnected the battery for about ten mins but it's still the same.
    I'm about to get two new tyres and want to put them on the front but don't want the sensors the wrong way around
    [Ex]Admin Duncan's Avatar
    Pretty sure it's a Tech 2 or Vaux-Com job.
    @home
    Engine : 1.9 CDTi
    Poo...
    You'd think they'd have a menu option to reset and to adjust the PSi values in the TPMS menu.. Guess the fronts are staying at the front then.
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    yeah as duncan has said it has to be tech2`d m8 as once its been
    programmed with the trye pressures on each wheel then they cant be
    swapped round on the car as the compurter knows wot wheel is wot on
    each corner.
    wot i will do is check with my dr tech2 and get back to you
    Admin plasma's Avatar
    On the Forum
    321 Post(s)
    Engine : 150
    Mileage : 74000
    The way it works is in pairs, ie front and back, and it determines which is where by the signal strength it receives, so swapping side to side should be ok, and i would have thought front to back would be ok too. Wouldnt have thought the signal would be strong enough to reach from the front to the back, but we'll wait and see what andys mate says.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Tpms
    By R2XPT in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2012, 14:47
  2. Where to buy TPMS sensors?
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2011, 11:27
  3. TPMS or DDS????
    By deejer73 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 18:16
  4. TPMS Fault
    By Chuddy in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2010, 20:56
  5. tpms
    By kpf1grandprix in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 19:00
vectra c tpms reset
vauxhall vectra tpms reset
