Results 1 to 10 of 28
Thread: Climate control not working at all
    Jun 2009
    Birmingham
    Default Climate control not working at all
    Hi
    New here... hello!
    I don't have a Vectra, my dad does so posting this on his behalf. He has a problem with the climate control on his Vectra Elite. Quite simply the fan does not work at all, on any speed. And if I remember correctly when you press the A/C button it does nothing, no light.
    I have checked the fuses / relays etc all ok. Also did an ECU reset by disconnecting the battery for a while.
    I did a bit of searching on here and there seems to be a fairly common fault with the interior fan only working on certain speeds. Do you think this could be the same issue (i.e. water ingress damaging the circuit board)?
    Is there some sort of guide available on how to get to the fan and control board?
    Thanks in advance,
    Iain.
    Jun 2009
    Birmingham
    It's a 7 speed by the way...
    It could be but it could be the CC board itself as mine started to fail and I had it replaced under warranty.
    Regular Member Jezzy's Avatar
    S.E
    Check to see if the bung hole located under the windscreen scuttle is blocked, hence letting in water which may have damaged the fan/heater electrics. The bung hole is located near the pollen filter.
    Jun 2009
    Birmingham
    Is that attached to the fan? Bet its expensive
    Ok will take a look, don't mind a bit of DIY so we'll see if it's anything obvious! Thanks for your help.
    check the heater resistor pack for water damage. I had the panel with the controls on replaced, no idea on the cost
    Jun 2009
    Birmingham
    Ok just an update. I checked the drainage hole which looked quite clogged so I cleared that out.
    I removed the pollen filter and check the fan which I could spin freely.
    Then I removed the glove box. No sign of any water damage at all. Cant find any resister - is there one for this model? Could only see a bunch of solenoids.
    Removed the two relays, tested those ok.
    Is there a way of checking the fan? There are 4 wires going to it.
    Cheers!
    East Midlands
    If the fan doe'nt work on all four settings mate,it's odds on its the fan motor itself thats goosed,the fan resister pack controls the speed of the fan,and if that is knackered the fan will still run on setting 4...hard wire the motor itself and see if it does actually work....Hope this helps.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    climate control has 7 settings and i dont think it has a resistor pack in the usual place.
    FI23 (fuse box left hand side of dash with door open 40amp) is the main power feed for it.
    The regulator for it appears not to in the standard aircon position but further up to the left near the door pillar. Looks like a glovebox out jobbie to see it.
    FI2 (7.5amp) is the power feed to the aircon switch unit, does this work and show which speed its trying to work at on the display screen?
    Jun 2009
    Birmingham
    Quote Originally Posted by macdad View Post
    It's a 7 speed but guess it works in a similar way. There are 4 wires going to the motor, any idea why there are 4?
    Quote Originally Posted by plasma View Post
    Forgot to say I did check those fuses, all ok. The display works ok and displays the speed. However pressing the Auto button no longer illuminates the led.
    I put my multimeter randomly across the motor wires and there was a contant 12v on 2 of them, and a varying voltage (as you adjust the speed) across another 2. This would suggest to me that the motor is knackered. But the garage that my dad took the car to for its Mot said they tested the fan and it was ok.
    Does anyone have a wiring digram? If I can figure out what each wire does that goes to the blower I can test it for myself.
    Thanks again.
  1. Climate control not working properly
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 13:28
  2. climate control panel not working
    By mikeeaston in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:53
  3. OPEL Vectra C - Climate Control Not Working
    By Tigra16V in forum Vectra C / Signum Troubleshooting
    Last Post: 5th June 2011, 22:07
  4. Climate control not working
    By steviemac74 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2008, 19:00
  5. Climate control not working properly
    By Aussie in forum Bodywork & Interior
    Last Post: 13th November 2007, 22:49
vauxhall insignia climate control problems
vectra heater blower not working
vectra c heater not working at all
vectra c heater control panel not working
insignia sri heater control not working
vauxhall insignia climate control stopped working
opel vectra 2.2 ac panel not working
vauxhall vectra c climateheater control panel unit dont work
vauxhall vectra heater not working
vectra c heater control not working
opel insignia temperature knob not working
insignia blowers not working
vectra c air mixture flap control with automatic climate control
vectra c 7 speed climate control comes on then goes off
zafira heater control not working
vauxhall vectra heater fuse
fox vectra c dual climate control panel
change vectra c air con to climate control
vectra heater not working site:www.vectra-c.com
vectra b automatic climate blower not working
vectra c interior fan not working
my heater knob dont work vectra c
opel vectra c ac button not working
vectra c climate control connector
