Results 1 to 10 of 21
Thread: swirls!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Default swirls!
    my car looks nice shiney and smooth but under the lights at night it looks a bit swirley
    what stuff would you recomend?
    i really dont want to use somethink really corse as i might go through the paint
    somethink easy to use would be a billy bonus
    cheers guys
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    http://www.chemicalguysuk.com/product_p/all1.htm
    This stuff works well, and seems to be very gentle too, even on my first go with a rotary it came up well, so you should have no problem with it.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Rich,
    Some time ago I used megs stages 1,2 and 3. The write up is here:
    http://www.vectra-c.com/forum/showthread.php?t=22238
    It did the trick for me.
    Cambridgeshire
    Dan is right pointing you in the direction of the CG stuff it is the best in my opinion.
    If the swirls are quite bad you could also try CG Pro Polish. I've got some on order as I've got another car to detail on the weekend and i'll let you know how I get on with it The All-In-One Polish is a great starting point or if the swirls are not too bad
    birmingham
    Engine : 3200
    Quote Originally Posted by parsco View Post
    cheers m8, i think i will have a go with the cg all in one, i have the silverline polisher with 6 speeds...what speed do i useit on?
    cheers
    Cambridgeshire
    There is something called the Zenith Point that you need to work to when you are doing correction mate.
    It will go something like this:
    - Spreading
    - Begin Cutting
    - Cutting to remove defect
    - Cutting to remove defect even more
    - Cutting to remove marring
    - Burnishing
    So bearing that in mind i work on:
    2 passes at 600rpm to spread the polish ready for use
    2 passes at 1200rpm to begin working the polish
    4 passes at 1500rpm to work the abrasives to remove the defect
    4 passes at 1800rpm to continue working the abrasives to remove defects
    4 passes at 1500rpm to remove inflicted marring with the now lighter cutting abrasives
    2 passes at 900rpm to burnish the finish to a high gloss
    This will take a long time but you will need to take your time to achieve the best results mate Just keep an eye on the area you are working on and try not to do it in direct sunlight. Good luck
    birmingham
    Engine : 3200
    - Spreading
    - Begin Cutting
    - Burnishing
    jeez!!! there seems a lot of work there....i will let you know how i get on
    Cambridgeshire
    You're not kidding mate good luck
    Chester
    Have a look at DaveKGs guide on DW Rich. There's one for a Rotary and a DA.
    You could get it horribly wrong if you try paint correction without having a basic knowledge of what you are trying to achieve with a Rotary.
    I'd stick with what Steve suggested (on the motor) until you at least get yourself a practise panel to play with and use that guide to apply the process correctly.
    birmingham
    Engine : 3200
    Quote Originally Posted by Stevel View Post
    cheers for the advice, the guy over the road has an old bmw so i might ask him if i can practice on his first, i will have a look at the guide aswell,cheers steve
  1. Swirls
    By rob warrington in forum Detailing and Car Care Discussion
    Last Post: 8th January 2012, 17:30
  2. swirls
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 8th August 2011, 15:50
  3. swirls
    By Matt&Jemz in forum Detailing and Car Care Discussion
    Last Post: 22nd May 2009, 18:08
  4. Swirls
    By Sean-2.2Direct in forum Bodywork & Interior
    Last Post: 27th November 2008, 11:01
  5. Swirls..
    By Dwabo in forum Detailing and Car Care Discussion
    Last Post: 5th March 2006, 09:54
