Thread: magnex cat back exhaust problems
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default magnex cat back exhaust problems
    as above ever since fitting it it always comes loose after the cat, had it into a garage 3 times to tighten the clip...would it be possible to weld the magnex system to the cat and would I be able to get it removed later if I sell the car?thanks
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    btt
    WGAF#5
    if it keeps coming loose its doing it for a reason
    either the clamp is faulty - or not man enough for the job
    or the flanges are not lining up correctly and then the subsequent flexing of the joint is causing the pipes to jump apart - i'm personally in favour of the latter - would take it back to who ever did the initial work and ask them to check the flanges for damage and if necessary reweld the parts as required
    they could alsoas you requested remove the clamp cust the flanges off weld a sleeve over the joints -this would however make it very difficult to remove later
    hth
    regards
    Dez
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    mines a 1.8 I think a couple of other people have the same problem with it blowing as the magnex system is just slightly too big a bore for the standard pipe
    WGAF#5
    Quote Originally Posted by Morephun View Post
    and thats why the clamp wont work
    they need to be a mathced size to clamp together - best solution
    cut off and have welded in situ
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    had my reducer welded to the front pipe mate. its not blowing anymore from there but the ****ing thing is whistling somewhere as i rev it hard and when im pulling away.
    doing my ****ing god dam head in. lol
  1. Magnex Cat-back
    By John LE in forum Diesel Engine related
    Last Post: 11th December 2009, 20:38
  2. Magnex back boxes.
    By jamesr in forum General Chat
    Last Post: 5th July 2008, 23:04
  3. 5x3 oval magnex back box.
    By kev bux in forum Styling
    Last Post: 5th November 2007, 19:13
  4. Complete Magnex Cat-Back System Here!
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2006, 20:21
