Thread: twin back boxes
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    Default twin back boxes
    i have the chance of 2 back boxes 1 either side what i need to know is will it fit my 1,9 cdti it is off a 2t and what should i be looking to pay for it it is full all the way to front of car i only want the right box realy and y peice so will it come apart easy cheers
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Not as simple as one box and the Y mate. The left box is different to a single left box in that the pipework is about half the size to help keep back pressure and equalise the pressure to the other box. I just put a 2.0T rear section on my single 2.2. All I did was cut my old system off before the Y and replace it with the 2.0T rear system.
    sound so just cut it b4 y then get it welded back to mine
    Leicester
    There is a how to that I wrote for this very conversion.
    You need to keep your original left hand silencer, then use the 2.0T right hand box and fit a Y piece, Irmscher is the best place for this as they already have one for this conversion.
    It is very easy.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by willoftoon View Post
    I just clamped mine with some exhaust putty as the 2.0T centre section is larger than the stock 2.2 50mm
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Maverick View Post
    It is very easy.
    Do they smoke equally? As I mentioned, the pipe on the stock left hand 2.0 box is like a pea shooter compared to my stock single 2.2 one.
    Leicester
    Yes they do pretty much, they act in the same was as a car which has them fitted at the factory.
    My last 1.9 150 Vectra and my current Signum 1.9 150 have both had the conversion and they smoke pretty evenly on tick over but under throttle, any smoke you may expect is equal both sides.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
  1. Twin Exit Without Back boxes...
    By DarylAAS in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 12:33
  2. Twin Back Boxes
    By signumboy in forum Parts for sale
    Last Post: 11th December 2009, 22:10
