Thread: how do i apply Collinite
    Regular Member the fisherman's Avatar
    manchester
    Default how do i apply Collinite
    do i just polish the car with a polish them just put the wax on and wipe of??????????????
    Full Member spennny's Avatar
    Blantyre
    Yep thats how i do it, wax on .....wax off
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    I leave mine on for about one hour then take it off then next day wash /dry car and reply it again .
    Regular Member Little John's Avatar
    North West
    Apply a coat using a foam applicator pad multiple thin even coats are much better than thick layers, so apply it all over the car thinly leave for 20 minutes or so and buff the wax with a microfibre cloth. Leave the car for 24 hours if you can in a garrage then apply a 2nd coat useing the same method and buff it off.
    Putting it on too thick makes it difficult to buff off, takes longer to cure and wastes the wax as only the wax touching the panel is left behind when you buff it off. You will also use more microfibre cloths buffing thick wax layers.
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    also try a damp applicator... with a little spruce of last touch or quick detailer... helps to spread the wax evenly...and so doesnt end up too thick...
    leave the wax to haze .. to test just give it a quick wipe with your finger.. if it comes off then the wax is ready to come off..
    manchester
    cheers guys imgoing to try it tomorrow when at the garage.ill let you no how i get on thanks
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Which Colly are you using? I found the 915 a pleasure to use; easy on & easy off with great results. I use the same method as dwabo.
    manchester
    915 m8
  1. How much performance boost for about 2k, and how best to apply it?
    By Coupe2T in forum Diesel Engine related
    Last Post: 11th February 2013, 23:48
  2. carbon fibre film how to apply it?
    By mrk in forum Styling
    Last Post: 6th September 2012, 20:11
  3. would double the size plus 2 psi still apply here ??
    By Deztroyer in forum The 'Off Topic' room
    Last Post: 25th May 2011, 18:35
  4. New paint, what to apply as the first layer
    By Ginge7289 in forum Detailing and Car Care Discussion
    Last Post: 24th February 2011, 22:19
  5. How to apply Brake Decals
    By JSYSH466Y in forum Styling
    Last Post: 1st March 2009, 13:17
