Results 1 to 10 of 18
Thread: help with bonnet catch
    Regular Member SRimonkey's Avatar
    wednesfield
    Default help with bonnet catch
    car just came up on the lil screen thing that the water needs topping up....pulled the bonnet catch down in my footwell and...............nothin!! help can`t get the bonnet up
    Nottinghamshire
    Get someone to pull the bonnet release lever out all the way (as far as it will go without snapping it) while you stick your fingers under the bonnet and try to lift it up.
    Sounds like the bonnet release needs adjusting - check it out before you drop the bonnet again (when you can open it in the first place that is).
    HTH
    wednesfield
    Quote Originally Posted by James24 View Post
    HTH
    lol....the bonnet dont budge,lol i`m gonna grab the wire off the lever an yank it with some pliers
    Newcastle under Lyme
    could be the other end?
    wednesfield
    Quote Originally Posted by JSYSH466Y View Post
    then i`m stuffed
    Just turn the car upside down and work from the bottom?
    wednesfield
    helpfull today ain`t ya!!! and 4 ya ps3,just buy a crap surround system for about 20 quid from asda
    Nottinghamshire
    Quote Originally Posted by SRimonkey View Post
    My method did get my bonnet to open when the mechanism was badly adjusted for some reason (I don't think it had been set up properly from new).
    Your idea with pliers may work if the cable has slipped through the clamp under the bonnet and the lever won't pull it out far enough to release the bonnet. If you pull with pliers and the cable just keeps coming then it must have snapped.
    I did get into a Nova many years ago using a screwdriver pushed through the grille when this happened, but I guess the mechanism will be a lot more closed in on the Vectra to stop thieves doing this.
    Best of luck.
    Plymouth
    is there any way u can slide ur hand up from underneath the bumper and manually disengage the lock?
    Every little helps (oh no thats tescos) cheers for the tip on the sound system btw
  1. bonnet catch
    By kristian in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 21:50
  2. Bonnet catch...
    By david.aka.judas in forum Bodywork & Interior
    Last Post: 5th April 2010, 20:16
  3. bonnet catch
    By scriv in forum Troubleshooting
    Last Post: 7th January 2009, 12:10
  4. Bonnet Catch
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 07:58
  5. Bonnet catch
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2006, 10:11
