Results 1 to 3 of 3
Thread: Idle chirp
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Default Idle chirp
    My dti has developed on idle 'chirp'. In neutral, with the clutch pedal up, it chirps. It started small and is developing to more of a full time squeak! It totaly stops when you push the clutch down! wiggling the gear selector on the gear box seems to stop it too! Any ideas?
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Normally if its only when you let the clutch up its something like a thrust race bearing. But could be the final drive on the gearbox too maybe? but not sure why touching the linkage would stop it?
    May 2006
    somerset
    that sounds costly! its only done 48k! surely it can't be in trouble already!!!
    only had it 2 months!
  1. Alternator chirp
    By tbclose1992 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 21:14
  2. Metallic Chirp\Squeak going over speed humps
    By joules2.0t in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2012, 21:23
  3. Noise when starting 3.2 (like a chirp!?)
    By effone in forum Engine & Drivetrain
    Last Post: 21st November 2008, 15:34
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. can i make alarm chirp
    By scottie in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2006, 10:40
