Thread: Swirl valve actuator
    Oct 2007
    Scotland
    Default Swirl valve actuator
    As I mentioned in another thread, my swirl valve actuator rod is off and I am going to try the £1 "how to" fix. Just one question though to the guys that have done it - is the actuator rod straight? I ask this because it looks as if mine has a kink in it and the plastic cup at the end ( 4th one) sits about 1 cm higher than the other three. If I put it on a level surface the first 3 sit on the table but the 4th doesnt.
    Can any one confirm before I get the straightening hammer out?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Don't straighten it, thats how its supposed to be mate - good luck with the "quick" fix though
    Oct 2007
    Scotland
    mmm cheers Dan but I am not so sure.
    Did the £1 fix (98p actually :P) and the first three clip over the pins but the 4th slipped off the first time I revved the engine. Not 100% sure that I hadit on the pin in the first place to be honest so I will monitor it. Might have to take it off and give it a little bend to make sure it stays seated.
    First class fix though - really impressed with the ingenuity pete_mc
    Oct 2007
    Scotland
    just wanted to check the bend in the rod.
    As I mentioned above the rod has a kink in it and if you sit it on a flat surface only 3 touch the surface and the 4th is about a quarter inch higher.
    Checking a few threads and some piccies i get this >
    http://www.ms-motor-service.com/xima...093_en_web.pdf
    If you look closely at the picture of the rod on page 2, the kink is between swirl valves 1 and 2.
    On this piccie >
    http://www.infrasolve.com/ABTEMP/oldinlet1.JPG
    The kink is between swirls 3 and 4.
    I originally thought that the kink should have been between 3 and 4 but 4 kept popping off. I turned it around last night and had to force it a bit but its on and seems to be attached to the valves.
    Still not 100% so could someone clarify for me?
    On another note - would my arguement with VX about a manifold replacement be blown out of the water cos I have done this repair?
    Oct 2007
    Scotland
    Anyone?
    Oct 2007
    Scotland
    No-one?
    Wales, UK
    Really sorry, I cant help but here is another thread bump for you!!!
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    i would doubt it as long as vx have already inspected the car i've been told how to do tempry repairs by vx techs loads of times to keep a car going till its booked in even running bout with one now
  1. Swirl valve actuator bar
    By Big Si in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 08:34
  2. Swirl valve actuator--Connection Bar
    By chrisgettings in forum Diesel Engine related
    Last Post: 27th September 2011, 19:57
  3. Connection between swirl valve and the actuator
    By genesisfm in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2011, 19:58
  4. swirl valve actuator
    By wirrallad in forum Engine & Drivetrain
    Last Post: 4th August 2009, 19:54
  5. Swirl valve actuator
    By oxenburger in forum Engine & Drivetrain
    Last Post: 24th March 2009, 19:17
