Thread: Signum 06 Model Year Enhancements
    Regular Member rmcevoy's Avatar
    Warwick
    Default Signum 06 Model Year Enhancements
    I have an 06 model year Signum. I know that the front light cluster and spec levels were changed and I have read on this site that the spec levels have generally gone down down on the 06 model year.
    That said, who knows of any mechanical/improvements changes made to the range for the current model year cars?
    Thanks!
    The facelifted models got the chassis/suspension tweaked to give better handling/composure on the road. I know they dropped the overhead storage that the pre-facelift Signum used to have.
    As for the exact spec differences, I'm not entirely sure. Have a look at this thread and you can then compare previous models to the current one.
    HTH
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Unfortunately from what I've seen the spec in the design has quite a few things missing that my 05 design has, typical Vauxhall as they seem to do this quite a lot.
    If you park the old style Vec / Signum rear to the wind, and it is above say a force 10 gale, and you open the bonnet the hydraulic lifter can fail and the bonnet would close on you so VX have kindly done away with the self opening bonnet and replaced it with a metal pole which should be a lot safer in a hurricane ..
    There do you feel better now that you have something better / more mechanical on your improved version
    Warwick
    .....umm
    Cheers guys - just as I had concluded: not a lot! I noticed on a neighbours Sig the 'red safety' light you see when you open the tailgate is one item removed from the spec too for 06 models!
    But uprated suspension is probably better than the toys as these can be added later, do you still have a space for the storage in the roof ?
    Warwick
    Quote Originally Posted by Bainie
    I have bought a used travel assist! So my spec is going up ... just need the Navi DVD90 instead of the 70
  1. Model Year 2007 onwards - Front spring failures?
    By I cdti in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2012, 21:28
  2. Model @ year with mp3 aux jack
    By btetsola in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2009, 17:16
  3. Vectra Model year changes
    By woofywoof in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 11:39
  4. Model Year From chassis number?
    By ecm in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 10:08
  5. model year differences
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2006, 18:26
